Wireless Client to Wireless Client access not working.
rcancel
Community Member
I have a integrated Cisco Wism on my 6506. I'm running EIGRP. All networks see the wifi clients. Everything works great, except for sharing printers or pinging. I can ping from one wireless client to another, as long as they are not on the same site (i.e. LA to NY). If I try to ping a wireless client from a local wireless client (i.e. LA to LA), everything times out. It seems that if I access a wireless client from a wireless client within the same network, they don't see each other. However, wireless clients from one site can access wireless clients at another.
Any hints would be greatly appreciated!!
Thanks!
Reinaldo
Leo Laohoo
Go to WLAN > WLAN ID of your choice > Advanced Tab > and enable "P2P Blocking Action".
Leo Laohoo
Thank you so very much!! It worked!!!
Thank you very much for the ratings.
