Wireless clients having issues with WLC
Bali Khan
Hi - I am working on an issue and need urgent help as it has been going on since couple of weeks.
We have Anchor (Main) WLC which is working as DHCP server with a lease of(192.168.128.11-> 192.168.129.255) range for guests / visitor wifi.
There are 3 Foreign WLCs connected with WLC which have several APs connected.
Users when connect to wifi are asked for sign-in page where they put username/password (goes to authentication servers) and can then log in and do browsing.
Some users complain when they log in, but they cannot browse. For some users its fine.
What I have done so far:
1. On Anchor controller DHCP leased is set for 1 hour and it has /22 pool but normally during peak hours maximum 150 - 200 appear in leased table. so I ruled out DHCP leased problem or expiry timing issues.
2. I ruled out APs as well as it happens randomly.
3. But on foreign controllers some times, I see below messages :
apf_radius.c:2066 'AcctStop' clt MAC: c8:v6:f5:8a:e6:ab  AP MAC: 00:c8:7d:9c:b8:d0 Role 'Handoff' PemState 'DHCP_REQD' SSID 'Visitor' Connected for '4' secs
apf_radius.c:2066 'AcctStop' clt MAC: 60:a5:7u:f5:bf:bd  AP MAC: 00:c8:8c:9c:b6:f0 Role 'Export Foreign' PemState 'DHCP_REQD' SSID 'Visitor' Connected for '133' secs
*apfReceiveTask: Dec 22 08:43:56.850: #APF-3-NO_FRAMED_IP_ADDRESS: apf_radius.c:2066 'AcctStop' clt MAC: 00:ae:fa:ee:cc:cc  AP MAC: 00:c8:7:1a:c5:00 Role 'Export Foreign' PemState 'START' SSID 'Visitor' Connected for '22' secs
4. On Anchor WLC I see this in logs:
Bad DHCP packet from 192.168.128.4, dropping
*DHCP Server: Dec 21 23:04:33.202: #DHCP-3-BAD_DHCP_PKT: dhcpd.c:529 Bad DHCP packet from 192.168.128.4, dropping
*DHCP Server: Dec 21 23:00:26.496: #DHCP-3-BAD_DHCP_PKT: dhcpd.c:529 Bad DHCP packet from 192.168.128.4, dropping
*DHCP Server: Dec 21 23:00:24.798: #DHCP-3-BAD_DHCP_PKT: dhcpd.c:529 Bad DHCP packet from 192.168.128.4, dropping
*DHCP Server: Dec 21 23:00:20.491: #DHCP-3-BAD_DHCP_PKT: dhcpd.c:529 Bad DHCP packet from 192.168.128.4, dropping
*DHCP Server: Dec 21 23:00:16.061: #DHCP-3-BAD_DHCP_PKT: dhcpd.c:529 Bad DHCP packet from 192.168.128.4, dropping
*DHCP Server: Dec 21 22:57:54.626: #DHCP-3-BAD_DHCP_PKT: dhcpd.c:529 Bad DHCP packet from 192.168.128.4, dropping
*DHCP Server: Dec 21 22:57:49.976: #DHCP-3-BAD_DHCP_PKT: dhcpd.c:529 Bad DHCP packet from 192.168.128.4, dropping
*DHCP Server: Dec 21 22:57:47.794: #DHCP-3-BAD_DHCP_PKT: dhcpd.c:529 Bad DHCP packet from 192.168.128.4, dropping
*DHCP Server: Dec 21 22:56:54.782: #DHCP-3-BAD_DHCP_PKT: dhcpd.c:529 Bad DHCP packet from 192.168.128.4, dropping
Dec 21 17:51:36.196: [ERROR] ews.c 871: ewsRun: Bad State - should be suspended: 0x0
*emWeb: Dec 21 17:22:03.366: #SYSTEM-3-PASSWD_STORE_INTEGRITY_FAILED: passwd_store.c:475 Cannot retrieve secret from store -- integrity check failed.
*emWeb: Dec 21 16:22:08.900: #SYSTEM-3-PASSWD_STORE_INTEGRITY_FAILED: passwd_store.c:475 Cannot retrieve secret from store -- integrity check failed.
Dec 21 16:00:49.355: [ERROR] ews.c 871: ewsRun: Bad State - should be suspended: 0x0
*DHCP Server: Dec 21 15:21:12.577: #DHCP-3-ADDR_NOTIN_POOL: pools.c:172 Error: Ip Address 192.168.0.24 is not in pool (192.168.128.11-> 192.168.129.255)
Previous message occurred 27 times.
Dec 21 10:28:28.627: [ERROR] ews.c 871: ewsRun: Bad State - should be suspended: 0x0
*mmMobility: Dec 21 10:26:52.924: #MM-3-MIP_READ_ERROR: mm_mobile.c:891  Mip is corrupted, possible race condition. mmMyPending Q size = 0   mip->magicNumber = 0. Encountered memory error, Please report the error if you experience a crash.
Previous message occurred 21 times.
On non working users, I ran ipconfig / dnlookup / ping to gateway which look fine to me as IP is assigned correctly via DHCP Server / Anchor WLC.
The issue is that they cannot browse.  This is intermittent.
What the above logs mean on the Foreign WLC and Anchor WLC ?
Apart from that any other suggestion would be helpful as this is an urgent issue and going on since 2 weeks.
Thanks.
Rasika Nayanajith
Even thoug DHCP server feature is supported on WLC, it is not an ideal platform to run as a DHCP server.
I would think if you can use something else as DHCP server, you won't see this issue
Rasika
Leo Laohoo
Before going any further, can you confirm the affected users are able to obtain a valid IP address or not?
As what Rasika said, I don't recommend using the WLC as a DHCP server (for either AP and/or wireless clients).
thanks for your reply. Yes they do get valid IP from that range which we have assigned. IPconfig shows that but they cannot browse. DHCP range has 510 address - we normally have 150 - 200 users at one time. leased time is also 1 hr which is fine. this all was working fine 2 weeks ago. no change was made in the network around that time.
IPconfig shows that
Bah.  Post the complete output to the command "sh client detail <MAC address of one of the affected wireless clients>".
