Wireless clients not getting IP address
mohmann61
Wireless client not getting DHCP from LAN.  AP is setup as autonomous and there is only on VLAN configured on network with only one DHCP server.  Able to get some laptops to connect and get an IP address but others come back with a   169.254.232.15 IP address or it show 0.0.0.0.  It seems to be random which laptops can connect and which have trouble.  Getting these errors:
"Interface Dot11Radio0, Deauthenticating Station 64db.431f.2da4 Reason: Previous authentication no longer valid"
"Packet to client b46d.838d.b2a1 reached max retries, removing the client"
Never can get all 10 laptops and 2 tablets connected all at once.  I have done packet capture on DHCP server and do not even see DHCP discover hit the DHCP server.
Please see attached copy of the configuration.
This was resolved by moving AP to another switch and setting Association limit to 100.
6 Replies 6
Hi @mohmann61
 Which operating system are those who fail to get DHCP?
-If I helped you somehow, please, rate it as useful.-
There seems to be no rhyme or reason. It is Android, iPhone, Windows 7 various OS's. But it seems that we are only able to connect 10 wireless devices and the last device will not get an IP address so only 9 are able to connect and get an IP address. I have confirmed the Radios are set to Max Clients of 100. I have also confirmed the DHCP server has plenty of IP addresses available.
Is there a nother place that concurrent connections can be limited on the AP?
Maximum Allowed Clients on WLAN config
interface Dot11Radio0
 no ip address
 encryption mode ciphers aes-ccm
 ssid RK-AP1
 max-client 100
interface Dot11Radio1
 no ip address
 no ip route-cache
 ssid RK-AP1
 max-client 100
This is/was set to 100 but still not able to get more then are able to get an IP address.
They are able to connect but do not get an IP address.
If you look at the screen shot I send it shows this client with an address of 0.0.0.0
Packet to client 9097.f389.d9ee reached max retries, removing the client and it is not able to connect.
The client with Mac address 68a3.c4e2.7685 is a windows laptop and has the same problem.  But if they shut down another then this one will eventually connect and get an IP address.  I am very perplexed by this behavior.  Here is the log entries for this morning:
Jan 31 12:55:58.097: %DOT11-6-ASSOC: Interface Dot11Radio0, Station   b853.ac2f.ba10 Associated KEY_MGMT[WPAv2 PSK]
Jan 31 13:03:00.416: %DOT11-6-ASSOC: Interface Dot11Radio1, Station   b88a.606f.ad2e Associated KEY_MGMT[WPAv2 PSK]
Jan 31 13:03:10.584: %DOT11-6-ASSOC: Interface Dot11Radio1, Station   b46d.838d.b2a1 Associated KEY_MGMT[WPAv2 PSK]
Jan 31 13:03:42.948: %DOT11-6-ASSOC: Interface Dot11Radio1, Station   b46d.838d.bee5 Associated KEY_MGMT[WPAv2 PSK]
Jan 31 13:04:03.210: %DOT11-6-ASSOC: Interface Dot11Radio1, Station   b46d.8394.922e Associated KEY_MGMT[WPAv2 PSK]
Jan 31 13:04:23.233: %DOT11-6-ASSOC: Interface Dot11Radio1, Station   b46d.838d.bedb Associated KEY_MGMT[WPAv2 PSK]
Jan 31 13:38:52.255: %DOT11-6-ASSOC: Interface Dot11Radio0, Station   b853.ac46.6e5e Associated KEY_MGMT[WPAv2 PSK]
Jan 31 13:39:58.566: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station b853.ac46.6e5e Reason: Previous authentication no longer valid
Jan 31 13:39:58.570: %DOT11-4-MAXRETRIES: Packet to client b853.ac46.6e5e reached max retries, removing the client
Jan 31 13:40:49.320: %DOT11-6-ASSOC: Interface Dot11Radio0, Station   b853.ac46.6e5e Associated KEY_MGMT[WPAv2 PSK]
Jan 31 13:57:09.748: %DOT11-6-ASSOC: Interface Dot11Radio0, Station   6c76.6003.1a5c Associated KEY_MGMT[WPAv2 PSK]
Jan 31 14:02:09.988: %DOT11-7-AUTH_FAILED: Station 5c70.a32e.1524 Authentication failed
Jan 31 14:02:21.896: %DOT11-7-AUTH_FAILED: Station 5c70.a32e.1524 Authentication failed
Jan 31 14:06:12.937: %DOT11-7-AUTH_FAILED: Station 5c70.a32e.1524 Authentication failed
Jan 31 14:06:22.949: %DOT11-7-AUTH_FAILED: Station 5c70.a32e.1524 Authentication failed
Jan 31 14:06:33.049: %DOT11-7-AUTH_FAILED: Station 5c70.a32e.1524 Authentication failed
Jan 31 14:07:15.654: %DOT11-7-AUTH_FAILED: Station 5c70.a32e.1524 Authentication failed
Jan 31 14:08:47.858: %DOT11-4-MAXRETRIES: Packet to client 24da.9b14.0591 reached max retries, removing the client
Jan 31 14:08:47.862: (0000.0000.0000): dot11_mgmt:reached maximum retries,deleting the client
Jan 31 14:08:47.866: %DOT11-4-MAXRETRIES: Packet to client 24da.9b14.0591 reached max retries, removing the client
Jan 31 14:11:49.174: %DOT11-7-AUTH_FAILED: Station 24da.9b14.0591 Authentication failed
Jan 31 14:11:49.174: %DOT11-4-MAXRETRIES: Packet to client 24da.9b14.0591 reached max retries, removing the client
Jan 31 14:12:22.682: %DOT11-7-AUTH_FAILED: Station 5c70.a32e.1524 Authentication failed
Jan 31 14:12:38.766: %DOT11-7-AUTH_FAILED: Station 5c70.a32e.1524 Authentication failed
Jan 31 14:12:47.082: %DOT11-7-AUTH_FAILED: Station 5c70.a32e.1524 Authentication failed
Jan 31 14:13:10.926: %DOT11-7-AUTH_FAILED: Station 5c70.a32e.1524 Authentication failed
Jan 31 14:13:24.224: %DOT11-7-AUTH_FAILED: Station 5c70.a32e.1524 Authentication failed
Jan 31 14:14:18.160: %DOT11-7-AUTH_FAILED: Station 24da.9b14.0591 Authentication failed
Jan 31 14:14:25.711: %DOT11-7-AUTH_FAILED: Station 5c70.a32e.1524 Authentication failed
Jan 31 14:14:48.033: %DOT11-7-AUTH_FAILED: Station 24da.9b14.0591 Authentication failed
Jan 31 14:15:00.157: %DOT11-7-AUTH_FAILED: Station 5c70.a32e.1524 Authentication failed
Jan 31 14:15:32.503: %DOT11-7-AUTH_FAILED: Station 24da.9b14.0591 Authentication failed
Jan 31 14:16:25.892: %DOT11-7-AUTH_FAILED: Station 24da.9b14.0591 Authentication failed
Jan 31 14:16:40.340: %DOT11-7-AUTH_FAILED: Station 24da.9b14.0591 Authentication failed
Jan 31 14:17:34.688: %DOT11-7-AUTH_FAILED: Station 24da.9b14.0591 Authentication failed
Jan 31 14:18:26.770: %DOT11-7-AUTH_FAILED: Station 5c70.a32e.1524 Authentication failed
Jan 31 14:18:36.546: %DOT11-7-AUTH_FAILED: Station 5c70.a32e.1524 Authentication failed
Jan 31 14:18:42.424: %DOT11-7-AUTH_FAILED: Station 24da.9b14.0591 Authentication failed
Jan 31 14:18:52.925: %DOT11-7-AUTH_FAILED: Station 5c70.a32e.1524 Authentication failed
Jan 31 14:19:04.162: %DOT11-7-AUTH_FAILED: Station 5c70.a32e.1524 Authentication failed
Jan 31 14:19:44.970: %DOT11-7-AUTH_FAILED: Station 24da.9b14.0591 Authentication failed
Jan 31 14:20:18.766: %DOT11-6-ASSOC: Interface Dot11Radio0, Station   9097.f389.d9ee Associated KEY_MGMT[WPAv2 PSK]
Jan 31 14:20:38.522: %DOT11-7-AUTH_FAILED: Station 24da.9b14.0591 Authentication failed
Jan 31 14:20:50.427: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 9097.f389.d9ee Reason: Sending station has left the BSS
Jan 31 14:20:50.467: %DOT11-6-ASSOC: Interface Dot11Radio0, Station   9097.f389.d9ee Associated KEY_MGMT[WPAv2 PSK]
Jan 31 14:20:51.799: %DOT11-6-ASSOC: Interface Dot11Radio0, Station   68a3.c4e2.7685 Associated KEY_MGMT[WPAv2 PSK]
Jan 31 14:20:52.931: %DOT11-7-AUTH_FAILED: Station 24da.9b14.0591 Authentication failed
Jan 31 14:21:46.355: %DOT11-7-AUTH_FAILED: Station 24da.9b14.0591 Authentication failed
Jan 31 14:22:49.663: %DOT11-7-AUTH_FAILED: Station 24da.9b14.0591 Authentication failed
Jan 31 14:23:43.057: %DOT11-7-AUTH_FAILED: Station 24da.9b14.0591 Authentication failed
Jan 31 14:24:33.671: %DOT11-7-AUTH_FAILED: Station 5c70.a32e.1524 Authentication failed
Jan 31 14:24:45.443: %DOT11-7-AUTH_FAILED: Station 5c70.a32e.1524 Authentication failed
Jan 31 14:24:50.703: %DOT11-7-AUTH_FAILED: Station 24da.9b14.0591 Authentication failed
Jan 31 14:26:16.218: %DOT11-7-AUTH_FAILED: Station 24da.9b14.0591 Authentication failed
Jan 31 14:26:51.818: %DOT11-7-AUTH_FAILED: Station 24da.9b14.0591 Authentication failed
Jan 31 14:27:45.179: %DOT11-7-AUTH_FAILED: Station 24da.9b14.0591 Authentication failed
Jan 31 14:28:38.735: %DOT11-7-AUTH_FAILED: Station 24da.9b14.0591 Authentication failed
Jan 31 14:28:52.936: %DOT11-7-AUTH_FAILED: Station 24da.9b14.0591 Authentication failed
Jan 31 14:29:46.387: %DOT11-7-AUTH_FAILED: Station 24da.9b14.0591 Authentication failed
Jan 31 14:30:13.035: %DOT11-7-AUTH_FAILED: Station 5c70.a32e.1524 Authentication failed
Jan 31 14:30:21.395: %DOT11-7-AUTH_FAILED: Station 5c70.a32e.1524 Authentication failed
Jan 31 14:30:29.521: %DOT11-7-AUTH_FAILED: Station 5c70.a32e.1524 Authentication failed
Jan 31 14:30:37.835: %DOT11-7-AUTH_FAILED: Station 5c70.a32e.1524 Authentication failed
Jan 31 14:31:24.539: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 9097.f389.d9ee Reason: Previous authentication no longer valid
Jan 31 14:31:24.543: %DOT11-4-MAXRETRIES: Packet to client 9097.f389.d9ee reached max retries, removing the client
Jan 31 14:31:25.979: %DOT11-7-AUTH_FAILED: Station 24da.9b14.0591 Authentication failed
Jan 31 14:32:31.956: %DOT11-7-AUTH_FAILED: Station 24da.9b14.0591 Authentication failed
Jan 31 14:33:19.988: %DOT11-7-AUTH_FAILED: Station 5c70.a32e.1524 Authentication failed
Jan 31 14:33:25.508: %DOT11-7-AUTH_FAILED: Station 24da.9b14.0591 Authentication failed
Jan 31 14:33:33.208: %DOT11-7-AUTH_FAILED: Station 5c70.a32e.1524 Authentication failed
Jan 31 14:33:44.088: %DOT11-7-AUTH_FAILED: Station 5c70.a32e.1524 Authentication failed
Jan 31 14:33:55.799: %DOT11-7-AUTH_FAILED: Station 5c70.a32e.1524 Authentication failed
Jan 31 14:34:52.436: %DOT11-7-AUTH_FAILED: Station 24da.9b14.0591 Authentication failed
Jan 31 14:35:55.259: %DOT11-7-AUTH_FAILED: Station 24da.9b14.0591 Authentication failed
Jan 31 14:36:48.806: %DOT11-7-AUTH_FAILED: Station 24da.9b14.0591 Authentication failed
Jan 31 14:37:03.025: %DOT11-7-AUTH_FAILED: Station 24da.9b14.0591 Authentication failed
Jan 31 14:37:56.567: %DOT11-7-AUTH_FAILED: Station 24da.9b14.0591 Authentication failed
Jan 31 14:39:42.914: %DOT11-7-AUTH_FAILED: Station 24da.9b14.0591 Authentication failed
Jan 31 14:39:57.462: %DOT11-7-AUTH_FAILED: Station 5c70.a32e.1524 Authentication failed
Jan 31 14:40:07.923: %DOT11-7-AUTH_FAILED: Station 5c70.a32e.1524 Authentication failed
Jan 31 14:40:14.359: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station b853.ac46.6e5e Reason: Sending station has left the BSS
Jan 31 14:40:14.387: %DOT11-6-ASSOC: Interface Dot11Radio0, Station   b853.ac46.6e5e Associated KEY_MGMT[WPAv2 PSK]
Jan 31 14:40:36.484: %DOT11-7-AUTH_FAILED: Station 24da.9b14.0591 Authentication failed
Jan 31 14:41:30.077: %DOT11-7-AUTH_FAILED: Station 24da.9b14.0591 Authentication failed
Jan 31 14:42:25.672: %DOT11-7-AUTH_FAILED: Station 24da.9b14.0591 Authentication failed
SaukCentre-AP01#
