Wireless config on 2811 with hwic access point.
d.bigerstaff
I am running 2811 (ios 12.4(9)T) router with a 4 port switch module (HWIC-4ESW-POE=) and wireless module (HWIC-AP-G-E=).
What i would like to do is set up the wireless access point to be on the same network as the switch. But for now i'm trying to set up the Access Point as its own network and i will worry about bridging the devices later.
I've got the following configuration from reading http://www.cisco.com/en/US/products/ps6441/products_configuration_guide_chapter09186a00805d90f0.html
interface Dot11Radio0/2/0
ip address 192.168.30.1 255.255.255.0
ssid WLAN
authentication open
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0
station-role root
interface Vlan1
ip address 192.168.20.1 255.255.255.0
ip virtual-reassembly
Am i right in believing that the SSID isnt broadcast as default? How would i turn this on?
I have SDM v2.3.2 with wireless application installed so if that's easier to explain it's available.
Thanks.
Stephen Rodriguez
correct the SSID is not broadcast by default. the command you are looking for to turn it on is guest-mode. Issue this under the SSID on the DotRadio interface.
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
