Wireless connection
FinningCL
Level 2
Level 2
I have an issue with the wireless connection. The users almost always have problem with yours wireless connection, all the time the connection is restarting. I checked the logs on the AP 1242G and I don't find problems. Somebody help me please. I have installed one antenna in each AP.
6 Replies 6
George Stefanick
Hugo,
Welcome..
For starters you will need to share a little bit about your deployment. What model access points, firemware, how many access points, what type of wireless clients, how are your aps configured..
George, I have 27 AP's in 5 floors 6 for each floor and in the floor -1 3 AP's. the firmware is c1240-k9w7-tar.124-25d.JA1 and I attach the configuration
Hugo,
Can you share a little bit about your install. Did this work before, is this a new install? Is everyone getting disconnected or are someclients work and others arent ?
George,
From the beginning that I have the same problem. Some clients work and
others not.
Leo Laohoo
Excuse my ignorance but what do you mean by this statement?  What is connection is restarting?  An application?
Another thing, can you refrain from making multiple posts?  This will minimize confusion.
I connect my laptop to the wireless network and I am connected for 4
minutes and I see my connection again and I am disconnected and the
laptop try to connect the wireless again and is connected, but is
problem is all the time during day.
