Wireless Controller 2504 How to disable Hotspot
sundarthavamani
I am using 2504 wlc with wireless security PSK key. My employees are utilizing internet using PSK & they are sharing internet through thier laptop hotspot apps to unauthorized devices. How do i will block this type of Hotspot in the WLC?.
T.Sundar
M. Wisely
Level 4
Level 4
The best way to prevent this happening is to have an IT security policy that everyone has to agree to, stating that they can't connect unauthorized devices to the network (which is what they're doing) or run their own wireless network.
If you go to the monitor tab on your WLC and click on Rogues then Unclassified Rogues, click on the check box next to a rogue and click on contain. This may prevent clients from connecting to these rogues.
mohanak
The Cisco AVC solution for wireless networks identifies more than 1000 business- or consumer-class applications using deep packet inspection (DPI). This extraordinary visibility into application traffic allows administrators to mark applications for further prioritization, or block them for security reasons or to conserve limited network bandwidth.
http://www.cisco.com/c/en/us/support/docs/wireless/5500-series-wireless-controllers/115756-avc-guide-00.html
abwahid
Level 4
Level 4
You may enable a MAC based security in your environment to fix this issue.
http://www.cisco.com/c/en/us/support/docs/wireless-mobility/wlan-security/91901-mac-filters-wlcs-config.html
