08-02-2017 12:54 PM - edited 07-05-2021 07:28 AM
Can you up date the CT5508 with the usb stick?
I have a CT5508 that I want to update but it is not on the network and I would like to update with out putting on network first, is it possible?
08-02-2017 01:47 PM
USB is disabled.
08-04-2017 02:05 PM
You can configure service port and plug a Laptop with TFTP server app. See below post (it use for config replacement, you can do same for code upgrade)
https://mrncciew.com/2013/01/25/backup-restore-wlc-configs/
Rasika
*** Pls rate all useful reponses ***
