Wireless deployment question
turbo38v6
Community Member
Hi everyone,
I have a client that wants to use the spectralink phones which requires us to deploy wireless throughout his house. It's a very large home, with three floors and he would like to be able to walk from anywhere without dropping the call. Also, there is a coach house about 100 feet away that requires use of the spectralink as well.
I brought a 1230 AP to the site with a 2403B antenna and did some tests and came to the conclusion that 3 per floor would be required. Now here's where my questions begin. If I had 3 per floor, should I configure two of the 3 per floor in repeater mode. I'm thinking that this would avoid channel interference (i.e. 1st floor - channel 1, 2nd - channel 6, and 3rd - channel 11). Am I correct in this thinking??
Also, for the connectivity to the coach house, I would like to do a wireless connection as well. Only problem is that there are trees in the way. Can a high powered antenna overcome the interference caused by the trees??
Thanks everyone in advance for any help provided!!
Jennifer Huber
Level 3
Level 3
I would recommend against setting up the APs as repeaters. Each repeater offers half the bandwidth of the parent AP. You can setup the APs on each floor with the 3 non-overlapping channels in such a fashion that floor to floor overlap won't be a big issue. You can also adjust the power settings to reduce the same channel overlap. The rule of thumb for the same channel overlap restriction is no more than 4 APs on the same channel. If it were me setting this up, I would configure the APs like this:
1st floor
1 6 11
2nd floor
11 1 6
3rd floor
6 11 1
You could spread them through the house like this:
FIRST FLOOR
SECOND FLOOR
THIRD FLOOR
