Wireless Flash
tulasi_bharath2002
Community Member
I was using 1100 AP in which it has some IOS problem so on my boss request, i tried to change/upgrade the flash: c1100 file.
So, i deleted the flash file and at a sudden it completely went off red, green, red light order its glowing at status. It has only ethernet port no console so how can i copy the flash file now and make the device up.
Vinay Sharma
Level 8
Level 8
Hi Bharath,
Please check the article which explain about "Reloading the Image".it also talks about upgrade steps.
http://www.Cisco.com/en/US/customer/docs/wireless/access_point/12.3_2_JA/configuration/guide/s32trb.html#wp1038660
You can also have a look for Resetting the Device to  Default Settings:-
http://www.Cisco.com/en/US/customer/docs/wireless/access_point/12.3_7_JA/configuration/guide/s37frst.html#wp1103218
thanks,
Vinay
Thanks & Regards
