wireless monitoring on wlc controllers
carl_townshend
Hi all
Is there any kind of automated monitoring I can do on my cisco 4400 WLC controller, for example if I get dropped packets or a bad signal in certain areas etc?
cheers
Carl
George Stefanick
If you have WCS you can pull "caned" reports. Is that what you are asking?
