Wireless network setup
Hamilan Gnanabaskaran
Community Member
Hi, I need to get idea about wireless network with WiSM, WCS & WLC. Is there any link to start from basic to configuration guide. I want to know the protocols and design also.
Do WiSM and WLC do same functions?
Thanks.
Scott Fella
The WiSM and WLC has the same function. The WiSM is installed in a 6500 and the WLC is an appliance. Here is a good starting guide.
http://www.cisco.com/en/US/products/ps6366/products_configuration_example09186a0080665cdf.shtml
Sent from my iPhone
-Scott
Thanks, I do have WCS. How to configure WiSM via WCS. What are the important thing need to know.
That doc provides the basic of what you need to know to configure the WiSm or WLC. I would not bother with the WCS for configuration. Follow the doc and configure the WLC's manually and then when you have everything working you can setup WCS.
WCS can't configure your WLCs out of the box anyways.
-Scott
