Wireless solution for Telecommuter
r.ahuja
Community Member
Which is the better solution for individual telecommuters; Connecting to Wired LAN through point to point wireless bridges and access points
or
VPN-broadband connectivity, using VPN concentrator at the central site and VPN S/w or H/w client at the user end.
Please tell which is technologically and commercially better solutions. Also siting the price comparison for both the solutions
bbaley
Level 7
Level 7
This depends on how geographically diverse an enterprise you have. A VPN solution is certainly more flexible as far as this is concerned. Get in touch with a Sales Engineer, they should be able to present your options to you:http://www.cisco.com/warp/public/687/Directory.shtml
