Wireless Surveying
BJcomms64
Community Member
                   I intend to use an air-lap1131AG-E-K9 as a stand alone portable base station with airmagnet software on a laptop with a D link USB adapter for internal wireless surveys requested by a customer. My problem is that the base station has newly arrived and has the radios (2.4 & 5 Ghz)  disabled by default. I can get access to CLI using hyperlink but cannot see any way to simply enable transmission of radios. Any advice would be appreciated.
Barry
Scott Fella
Berry,
That ap is lightweight and if you are using it to survey, you need to convert that to ios. So you will need to download the iOS software from CCO and tftp the image to that AP.
-Scott
Scott Fella
By the way this is the model you should of purchased. The one you have is a lap1131.
air-ap1131AG-E-K9
Here is a link
http://www.cisco.com/en/US/docs/wireless/access_point/conversion/lwapp/upgrade/guide/lwapnote.html#wp160918
-Scott
