Wism Module Controller 2 not detect IP Address
Muhamad Badulisham Md Desa
Community Member
Hi, im badrul..i got one problem regarding the wism module controller. as we know in wism module have 2 controller, controller 1 and controller 2. i try to configure that wism module. but only controller 1 can used. for controller 2, it not detect the IP address that assign by DHCP. i try direct console on console port 2 on wism module, but it not detect console also. so i need help from who expert on this matter to soft my problem.
11 Replies 11
Justin Kurynny
Level 9
Level 9
Badrul,
Please issue the following commands on your 6500 CLI and post the output in a reply. Where you see , replace with the module/slot number where you have installed your wism.
show module
show wism status
show wism mod  cont 1 status
show wism mod  cont 2 status
Justin
Thanks Justin on your respond
here the commands :
sh module
Mod Ports Card Type                              Model              Serial No.
  1   24  CEF720 24 port 1000mb SFP              WS-X6724-SFP       SAL1329U59V
  3    6  Firewall Module                        WS-SVC-FWM-1       SAD1311014S
  4    8  Intrusion Detection System             WS-SVC-IDSM-2      SAD124101TB
  7    2  Supervisor Engine 720 (Active)         WS-SUP720-3B       SAL1326T4VZ
  9   10  WiSM WLAN Service Module               WS-SVC-WISM-1-K9   SAD132500BX
10    8  CEF720 8 port 10GE with DFC            WS-X6708-10GE      SAL15108PHU
11    4  CEF720 4 port 10-Gigabit Ethernet      WS-X6704-10GE      SAL1329U9DC
12    4  CEF720 4 port 10-Gigabit Ethernet      WS-X6704-10GE      SAL1416FNEH
13    8  CEF720 8 port 10GE with DFC            WS-X6708-10GE      SAL1517CGRF
Mod MAC addresses                       Hw    Fw           Sw           Status
  1  0026.0b5b.46b4 to 0026.0b5b.46cb   4.1   12.2(18r)S1  12.2(33)SXH5 Ok
  3  0021.a082.b420 to 0021.a082.b427   4.5   7.2(1)       4.0(4)       Ok
  4  0021.d869.d4e0 to 0021.d869.d4e7   6.4   7.2(1)       5.0(2)       Ok
  7  0024.1499.51d8 to 0024.1499.51db   5.9   8.5(3)       12.2(33)SXH5 Ok
  9  0024.9774.2344 to 0024.9774.2353   2.3   12.2(14r)S5  12.2(33)SXH5 Ok
10  c89c.1d2f.5a78 to c89c.1d2f.5a7f   2.3   12.2(18r)S1  12.2(33)SXH5 Ok
11  0026.0b5b.4694 to 0026.0b5b.4697   2.9   12.2(14r)S5  12.2(33)SXH5 Ok
12  8843.e11b.4eb0 to 8843.e11b.4eb3   3.1   12.2(14r)S5  12.2(33)SXH5 Ok
13  e05f.b974.e7d0 to e05f.b974.e7d7   2.3   12.2(18r)S1  12.2(33)SXH5 Ok
Mod  Sub-Module                  Model              Serial       Hw     Status
  1  Centralized Forwarding Card WS-F6700-CFC       SAL1329U27Q  4.1    Ok
  4  IDS 2 accelerator board     WS-SVC-IDSUPG      CFBG8260009  2.5    Ok
  7  Policy Feature Card 3       WS-F6K-PFC3B       SAL1326SS36  2.5    Ok
  7  MSFC3 Daughterboard         WS-SUP720          SAL1326T1EZ  4.0    Ok
  9  Centralized Forwarding Card WS-SVC-WISM-1-K9-D SAD1324048G  2.1    Ok
10  Distributed Forwarding Card WS-F6700-DFC3C     SAL1516C139  1.4    Ok
11  Centralized Forwarding Card WS-F6700-CFC       SAL1327TF1L  4.1    Ok
12  Centralized Forwarding Card WS-F6700-CFC       SAL1414EZAX  4.1    Ok
13  Distributed Forwarding Card WS-F6700-DFC3C     SAL1517CHK1  1.4    Ok
Mod  Online Diag Status
  1  Pass
  3  Pass
  4  Pass
  7  Pass
  9  Pass
10  Pass
11  Pass
12  Pass
13  Pass
show wism status
Service Vlan : 900, Service IP Subnet : 20.20.10.254/255.255.255.0
      WLAN
Slot  Controller  Service IP       Management IP    SW Version  Status
9     1           20.20.10.1          172.28.40.11         5.2.178.0      Oper-Up
9     2           0.0.0.0                0.0.0.0                                     Service Port Up
show wism module 9 controller 1 status
WiSM Controller 1 in Slot 9 configured with auto-lag
Operational Status of the Controller : Oper-Up
Service VLAN                         : 900
Service Port                            : 9
Service Port Mac Address        : 0025.84a9.a062
Service IP Address                  : 20.20.10.1
Management IP Address          : 172.28.40.11
Software Version                      : 5.2.178.0
Port Channel Number               : 417
Allowed-vlan list                       : 8,15,19,31,40-41,44,50-51,200,208,212,800,900
Native VLAN ID                        : 900
WCP Keep Alive Missed           : 0
show wism module 9 controller 2 status
WiSM Controller 2 in Slot 9 configured with auto-lag
Operational Status of the Controller : Service Port Up
Service VLAN                          : 900
Service Port                             : 10
Service Port Mac Address         : 0025.84ba.08a2
Service IP Address                   : 0.0.0.0
Management IP Address           : 0.0.0.0
Software Version                       :
Port Channel Number                : 418
Allowed-vlan list                        : 8,15,19,31,40-41,50-51,200,208,212,800,900
TQ again Justin...
Muhamad,
Thanks for posting your output.
Here are some quick observations:
  • I saw a similar issue once before, including getting no response from the console port on controller 2 and I think it may have something to do with the auto-configuration of the wism controllers and possibly the 5.2 revision of code. I didn't troubleshoot long enough to figure it out, but I was able to fix the issue, so I'll outline the procedure for you below. Hopefully it will help you.
  • I noticed that you have VLAN 900 on your wism portchannels, and because 900 is also your service VLAN, you do not (and should not) put it on the portchannels. Only the service ports need to be on VLAN 900. Also in this vein, you do not need to declare 900 as your native vlan on the controllers, and if your controller management interfaces are going to be in one of VLANs 8,15,19,31,40-41,44,50-51,200,208,212, or 800, then you do not need any native VLAN declared. You only need the native VLAN if you are going to leave your management VLAN ID tag at 0 (default).
  • Finally, and this is likely unrelated to your problem, but you are missing VLAN 44 on the controller 2 wism portchannel. If you want the same VLANs allowed on both wism controllers then be sure to correct the missing VLAN:
  • NOTE: You cannot have the controller management interface IPs and the service-port IPs in the same subnets.
OK, to try to recover from the unreachable wism controller 2 issue, try these steps:
1. Connect a console cable to the console port on wism controller 2 and start your console application
2. Separately, ssh/telnet to your 6500 (or on a console on another machine) and issue the command hw-module module 9 reset
... This will initiate a soft reload of the entire wism module
3. On your console, watch for your wism controller 2 to boot. When you see the the autoconfigure prompts, choose to exit autoconfiguration.
4. You should now be able to run through a basic setup wizard. Set the Service-Port config to DHCP (this should be the default).
5. When prompted to save and reboot, choose YES and this time around, you should see the controller come up and you will hopefully see that the service-port gets an IP
If you never see the wism controller 2 boot, then you may have a failed controller, so the next step may need to be a call into TAC.
Justin
thank you justin...
because willing help me to solve my problem and sharing  your knowledge and skills. however, i'm not use yet your way to  troubleshoot actually, because, after you give me the way to  troubleshoot this matter, i try tu put console cable on console  port controller 2, and then it display a basic setup. so, i'm just put the info that needed. and then service port  interface was got the IP Address. and controller 2 can be used now.
thanks again justin..
Muhamad,
I'm glad to hear that your wism is alive.
When you get a chance, can you mark this question as answered for the benefit of future searchers?
Thanks!
Justin
Justin,
Thanks for the good info. your explanation fixed my problem!
Community Member
hope anyone can help me again..
ok, i already install wism controller 1 and controller 2 and all connection is up. i want to move a AP in controller 1 to controller 2, i already set that AP use controller 2 as primary controler , and then i reset the AP. the problem is, the AP cannot move to controller 2 and in the same time its not in controller 1 also.
so, what the problem actually and how to solve this promlem?.
TQ
When you use the high availability, you need to make sure you use the controller name and ip address. Did you double check they are correct ?
thanks george...i did double check, i try again with another AP, move to controller 2 with set high availability, the problem still the same...
Is controller 1 and controller 2 in the same mobility group ? Is there an ACL anywhere that might prevent them AP moves?
Yes..already set in the same mobility group...but still cannot move...
