WLAN Broadcasting on wrong WAPs.
vosj
Community Member
Have a cisco 4402 manage. console and 1131AG WAPs I have a specific test LAN for one WAP but shows up on others WAPs too.  I need to stop this any ideas how?
George Stefanick
So if I understand you right you want to only allow your TEST ssid on a specific access point(s). You can do this with AP GROUPS.
Simply create an AP group and from that you can select what WLANs you want to have in that AP group. Then select the APs to assign that AP group to.
Keep in mind if you are on older code like 4.2 the AP group is configured differently then from 7.x. I would consult the config guide that matches your WLC code. But it takes less then 2 mins to do ...
I hope this helps.
If you find this helpful please rate the post!
vosj
Community Member
created a WLAN and created a AP Group VLAN that referenced the WLAN and then selected the the AP Group Name under the wireless advanced tab for the AP and yet after unplugging the AP I still see a broadcast coming from other APs that don't have the AP Group or the WLAN selected.
