WLC 2500 and AP 3602E
I have a problem with a WLC 2500 and 3602E the problem is the link speed between the AP and the client is weak
and the client is close to the  AP the version fo the WLC es 7.4 and don´t know if it is a bug with the version
because if I use a autonomous AP the speed is good
6 Replies 6
Scott Fella
Can you proved more detail. What radio band and how are you testing.
-Scott
The problem es in the 2.4 radio in the 5 there is not a problem, those AP´s before was working in autonomous mode
and the speed was good.
The problem has been since the WLC was installed. I tested with the task manager ande with the speed to the internet.
Leo Laohoo
3600E????
Did you install the right amount of antennas to the correct sockets?
Yes there are only 4 antennas and they are dual band.
What is the speed showing? Just because you has them in autonomous and now on the WLC doesn't mean anything. They are two separate wireless systems per say. On the WLC CLI, issue the show WLAN and post that. Make sure the clients have an updated driver also.
-Scott
Saravanan Lakshmanan
with local local mode AP, try: WLC>config ap tcp-adjust-mss all 1363
can you try on flexconnect local switching mode.
