10-21-2010 07:41 AM - edited 07-03-2021 07:19 PM
Hi All
Can anyone give me a definitive answer to this question please?
If you are using a pair of wireless LAN controllers configured with primary and secondary controllers for the access points and the primary controller fails - do the access points reboot before associating to the secondary controller. I can't see why they would need to but documentation suggests they do.
Additionally, has anyone significantly reduced the failover time? If so, what is the lowest practical failover time. I know the actual failover time can be reduced to 3 seconds but I think that is likely to cause other problems.
Thanks guys.
Roger
10-21-2010 10:16 AM
As far I know, In this case the AP does not reboot, only changes its lwapp status to discovery and begins with the discovery proccess.
You can see in the AP if it is restarted; when it places registered in the second WLC, Wireless tab and select the AP affected; normaly in the first tab you can see bottom right the AP up time and the AP association time; if this AP has rebooted this value will close to 00:00.
Normaly I set the Ap heartbeat timeout to 5 seconds, I don´t know if is the best value and my failover time is bigger than your, I don´t know how critical are your network, but a prefer a higher heartbeat timeout to avoid unnecessary AP changes that spend more time.
Best Regards.
10-22-2010 05:20 AM
Hi Raul
I can confirm that the AP does not reboot. I could not see any reason why it would.
Your heartbeat time would mean a total failover time of 15 secs which seems reasonable. I know you can reduce the heartbeat to 1 sec which would give a failover time of 3 secs but I think this would risk a lot of failovers occurring.
Roger
