on WLC with HA, I lost the connection via GUI.
I have juste access to the CLI on the service port.
here is Interface I got on the primary:
Interface Name Port Vlan Id IP Address Type Ap Mgr Guest
management 1 370 10.1.1.6 Static Yes No
redundancy-management 1 370 10.1.1.9 Static No No
redundancy-port - untagged 169.254.1.9 Static No No
service-port N/A N/A 172.16.15.115 Static No No
virtual N/A N/A 1.1.1.1 Static No No
here is Interface I got on the secondary:
>show interface summary
Number of Interfaces.......................... 5
redundancy-management 1 370 10.1.1.7 Static No No
redundancy-port - untagged 169.254.1.7 Static No No
service-port N/A N/A 172.16.15.116 Static No No
I already try to have access via GUI on the IP adress 10.1.1.6. it doesn't work too.
I m able to ping this IP address, I have verify the firewall, and all is good.
could you help me tu understand this issue?
regards
