WLC lost WEB and CLI after enabling FIPs
Mike_ATT_NY
I lost HTTP/HTTPS/CLI on my WLC after enabling FIPs. I can login, however with the console. I also lost all of my wireless profiles. Luckily, I'm testing in the lab.
6 Replies 6
Mike_ATT_NY
I also lost all the wireless profiles... luckily I'm in the lab..
Scott Fella
You did read up on the requirements for access when fips is enabled? I’m assuming you need to enable fips for government or you just testing?
https://www.cisco.com/c/en/us/td/docs/wireless/controller/8-5/config-guide/b_cg85/cisco_wlc_security.html#concept_7E605B4A99C746C5BA3F050FDA812C86
-Scott
I did read that document. It mentioned flushing out the old certificate & etc.. however, I was looking for some help to see if anyone has gone through this before.
Did you create a certificate after you enabled fips?
-Scott
I did configure FIPS and CC compliance, did not run into this issue you are referring to.
In addition to the document mentioned by Scott I also followed this document from Cisco.
At the time i was using 5520 with 8.5.
https://www.niap-ccevs.org/MMO/Product/st_vid10931-agd.pdf
-hope this helps-
I did generate the cert.
Here is the HTTPS error ->  Error code: SSL_ERROR_NO_CYPHER_OVERLAP
The Putty error -> Couldn't agree a key exchange algorithm (available ecdh-sha2 & etc)
I was able to clear cert/SSL state on IE and I get a login there, but login fails. I have removed FIPS, & etc. and I regain access.
