WLC - Right to Use Adder Licence
kameronr.chan1
I am wondering if a single adder licence can only be applied to one controller or if it can be used for both a primary and secondary controller. This is under the right to use agreement.
Ric Beeching
Level 7
Level 7
Hi Kameron,
If you intend to use both licenses actively then technically no you cannot do that under RTU licensing however technically if you are only consuming one license but it is applied to two appliances you would expect Cisco not to have a problem with that.
Ric
Please rate helpful / correct posts
