Showing results forĀ
Search instead forĀ
Did you mean:Ā
Work Group Bridge Setup Between Cisco AP and Aruba Controller
kcnajaf
Level 7
Level 7
I'm trying to setup a work group bridge between Cisco AP (AP1242AG) and Aruba Wireless LAN controller (MMC3200) with AP105 AP's. I'm running IOS version  c1240-k9w7-mx.124-10b.JDA3 on the Cisco AP and it this IOS support workgroup-bridge universal configuration.
Did any one had tried setting up work group bridge between Cisco and Aruba before and make it work?
Naz
5 Replies 5
Scott Fella
There have been another post like yours and there are issues.
https://supportforums.cisco.com/thread/2072128
The best thing to do is try it and see if it works. Here is a link you might want to look at also.
http://wirelessccie.blogspot.com/2010/09/workgroup-bridge-wgb-cli-commands.html?m=1
-Scott
HI Scott,
Thanks for the documents.
I have set this up and for some reason i can not even get the radio interface (dot11radio 1) up. It always stays on "reset" and down mode :-(
But when i change the role to root the interface comes up and clients are able to connect.
The configuration is attached for reference.
hostname WGB02
enable secret 5 xxxxxxxxxx
no aaa new-model
dot11 ssid Cisco
   authentication open eap eap_methods
   authentication network-eap eap_methods
   authentication client username WGB02 password 7 xxxxx
   accounting acct_methods
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
encryption key 1 size 128bit 7 xxxxxxxxxxxxxxx transmit-key
encryption mode wep mandatory
ssid Cisco
channel 2437
station-role root
rts threshold 2312
l2-filter bridge-group-acl
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface Dot11Radio1
no ip address
no ip route-cache
ssid Cisco
speed  basic-54.0
station-role workgroup-bridge universal 000c.8527.0213
rts threshold 2312
bridge-group 1
interface FastEthernet0
no ip address
no ip route-cache
duplex auto
speed auto
bridge-group 1
hold-queue 160 in
interface BVI1
ip address 10.10.10. 255.255.240.0
no ip route-cache
ip default-gateway 10.10.10.10
ip http server
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
bridge 1 route ip
line con 0
line vty 0 4
login
sntp server x.x.x.x
end
Najaf
Scott Fella
It is suppose to be Root.....
http://www.cisco.com/en/US/products/hw/wireless/ps430/products_configuration_example09186a00805b9b87.shtml
-Scott
Hi Scott,
Not sure how this will be the root :-(
I have the wired client connected to this AP and from the documentation (referring the the diagram under Network Diagram heading) which you send across in your previous post the AP to which wired clients are connected as configured as Work Group bridge.
Hope this clears your confusion.
Najaf
Your right... I was confused from another post I was looking at.  I noticed you disabled all your data rates except for 54.  That can be your issue.  Start of easy by clearing the config, set the hostname, ip address, SSID and staiton role.  See if the WGB works and then play around with the other settings.
Scott
Help out other by using the rating system and marking answered questions as "Answered"
-Scott
