WPA2 and Android issue connecting to WLC with 1142 Access points
bobph1957
STA is rejected by 802.1x daemon. Guest wireless devices will not connect, "auth failure". wpa2 psk
Had anyone experieced this issue and is there a work around?
Sandeep Choudhary
Hi ,
You should try with WPA.
Please change the setting to WPA and then try it.
I had roughly the same problem.  I set my router to accept WPA-PSK and the S710 to use WPA-PSK and it all worked fine. I tested WPA2-PSK again, and it refused to connect.
Hope it helps.
