ACL based Forwarding in Cisco 12000
rajithaudayanga
I have Cisco 12000 router running on XR 4.1.1 where i need to do below configuration.
track up_01
type rtr 103 reachability
track up_02
type rtr 113 reachability
track down_01
type rtr 104 reachability
track down_02
type rtr 114 reachability
ipv4 access-list DOWN
100 permit tcp any eq www any nexthop track down_02 1.1.1.2
110 permit tcp any gt 1044 any nexthop track down_02 1.1.1.2
200 permit tcp any eq www any nexthop track down_01 1.1.2.2
210 permit tcp any gt 1044 any nexthop track down_01 1.1.2.2
500 permit ipv4 any any
ipv4 access-list UP
100 permit tcp any any eq www nexthop track up_02 1.1.3.2
110 permit tcp any any gt 1044 nexthop track up_02 1.1.3.2
200 permit tcp any any eq www nexthop track up_01 1.1.4.2
210 permit tcp any any gt 1044 nexthop track up_01 1.1.4.2
interface x/x/x
description **UPLINK**
ipv4 address a.a.a.a b.b.b.b
bundle minimum-active links 1
load-interval 30
ipv4 access-group DOWN ingress
Issue is that i can not use NextHop option in ACL, Seems that is not available in XR 4.1.1
I found different opinion in http://www.cisco.com/c/en/us/td/docs/routers/xr12000/software/xr12k_r4-2/addr_serv/command/reference/b_ipaddr_cr42xr12k/b_ipaddr_cr42xr12k_chapter_01.html#wp5137027590
Do anyone have suggestion to do this config or any alternate configuration
xthuijs
hi there,
yeah you need PBR or ABF for this configlet you're showing.
dont believe that the GSR has that capability in that release.
If I see it right, then you need minimally 420+ for this functionality.
But also pay attention to the engine type cards you have, because there is likely a dependency there also.
xander
