XR OS and Platforms
“Take
HiI am looking for an option/configuration with which an IOS XR router doesn't allow conflicting/duplicate IP address configuration on two active interface.  Currently it allowing the conflicting/duplicate IP address configuration and bring an active...
bsn1980in by Level 1
  • 129 Views
  • 1 replies
We are currently facing an issue while trying to configure MVPN on a Cisco NSX540 running IOS XR. Our goal is to establish multicast VPN (MVPN) between PE routers. We have followed Cisco’s configuration guides and ensured that both unicast routing an...
We need to connect 2 Huawei firewalls working as Active & Standby using VRRP to an ASR 9904 with 2 Line Card (A99-4HG-FLEX-SE) for redundancy.We connect the first firewall normally, but the moment we connect the second firewall the first firewall bec...
Hello , I have a RR in the network and I want it to send all of the available paths to the Clients ,in order to do that, I have enabled the add-path feature on the RR as follow: router bgp xxxbgp router-id 44.44.44.44address-family ipv4 unicastadditi...
fbekhit by Level 1
  • 3782 Views
  • 3 replies
