ASR9K cef load-balancing with ISIS
AmyEST
Can you anybody explain how to load balancing with CEF running ISIS/BGP MPLS?
cef load-balancing ?
algorithm hash algorithm
fields hash fields
smilstea
CEF has built in load-balancing, you should only really change the cef load-balancing at the direction of TAC after a thorough investigation of a load-balancing issue due to polarization as it changes the load balancing for the entire router.
https://community.cisco.com/t5/service-providers-knowledge-base/asr9000-xr-load-balancing-architecture-and-characteristics/ta-p/3124809
Sam
smilstea
Sam
Thank you for sharing that useful info, Smilstea.
