BNG Questions
Nuno Marques
Hi guys,
trying to clarify a customer questions regarding BNG on the 9K:
- Does it send SNMP traps when ipv4/ipv6 pools threshould are crossed and then back to normal?
- Does it support ipv4/ipv6 conflit detection on PPP sessions?
thanks in advance.
xthuijs
Hi Nuno,
yes the pool mib should be supported along with the traps:
ftp://ftp.cisco.com/pub/mibs/v2/CISCO-IP-LOCAL-POOL-MIB.my
yes when the subscriber is inserted in the RIB, a dupe detection happens, if there is a dupe addr, we will reject the installation and disconnect the subscriber. so the IOS peer address unique ppp config command is "default" in XR for us indeed.
cheers!
xander
xthuijs
Hi Nuno,
cheers!
xander
Thx Alexander.
regards,
Nuno
