Connection Redundancy on ASR 9904
Al-Masaabi
We need to connect 2 Huawei firewalls working as Active & Standby using VRRP to an ASR 9904 with 2 Line Card (A99-4HG-FLEX-SE) for redundancy.
We connect the first firewall normally, but the moment we connect the second firewall the first firewall becomes unreachable and traffic does not pass through. We have the 2 interfaces connected in the ASR as Bundle-Ethernet & after searching for a while, it seems like Bundle-Ethernet will not be useful in this scenario (as it does not deal with 2 separate devices like in our case).
What are the options we have to connect the firewalls in this scenario while achieving redundancy in case the firewalls swap at any time.
M02@rt37
Hello @Al-Masaabi
Your asr9904 see these fw as two separate L2 endpoints. LACP requires a single logical device at the other end which your Hauwei’s VRRP setup does not provide.
So use two separate LACP bundles...one per firewall but not a single bundle shared by both, since LACP can’t span two independent devices.
Configure, for example, Bundle-Ether400 toward the active firewall and Bundle-Ether401 toward the standby, trunking the same VLANs (70, 71, 72, 74) on both.
Best regards
Thank you M02@rt37 for your reply. I wanted to know if there are any other options than Bundle-Ethernet to make this connection.
