grpc showing tcp port close from connected interface
Well I am having a problem when triyng to connect to grpc from a directly connected network. The port is showing as close from the pc but i can connect to the grpc service from xr 2 device without a problem.
I have tried with another interface with different ip configurations but with the same results.
I have replicated a success telenet connection from another router a hop away, directly connected like the topology shown.
Any suggestions?
Thank you very much
show version
Mon Jun 23 10:08:14.952 ART
Cisco IOS XR Software, Version 7.9.21
Copyright (c) 2013-2023 by Cisco Systems, Inc.
Build Information:
Built By : deenayak
Built On : Tue Nov 7 23:51:57 PST 2023
Built Host : iox-ucs-062
Workspace : /auto/srcarchive16/prod/7.9.21/asr9k-x64/ws
Version : 7.9.21
Label : 7.9.21
cisco ASR9K () processor
System uptime is 1 week 4 days 2 hours 29 minutes
show grpc status
Mon Jun 23 10:17:12.022 ART
*************************show gRPC status**********************
transport : grpc
access-family : tcp
TLS : disabled
trustpoint : NotSet
listening-port : 57400
local-connection : disabled
max-request-per-user : 10
max-request-total : 128
max-streams : 32
max-streams-per-user : 32
server name : DEFAULT
vrf-socket-ns-path : global-vrf
min-client-keepalive-interval : 300
_______________________________________________________________
*************************End of showing status*****************
show runn grpc
Mon Jun 23 10:30:56.601 ART
grpc
port 57400
no-tls
sho route 10.1.1.250
Mon Jun 23 10:31:29.375 ART
Routing entry for 10.1.1.0/24
Known via "connected", distance 0, metric 0 (connected)
Installed Jun 12 07:40:02.996 for 1w4d
Routing Descriptor Blocks
directly connected, via GigabitEthernet100/0/0/40.120
Route metric is 0
Redist Advertisers:
5 (protoid=5, clientid=13)
show running-config control-plane
Mon Jun 23 10:32:03.244 ART
control-plane
management-plane
inband
interface Bundle-Ether1
allow SNMP peer
address ipv4 10.1.1.0/24
interface GigabitEthernet100/0/0/40.120
allow SSH
allow SNMP
show runn inter gigabitEthernet 100/0/0/40.120
Mon Jun 23 10:36:23.503 ART
description xxx
mtu 9216
ipv4 address 10.1.1.1 255.255.255.0
encapsulation dot1q 120
23 Replies 23
Not sure if this has changed.
"Note that you can use any operational interface for the update-source, with the exception of dot1q-tagged VLAN sub-interfaces (as of IOS XR 6.2)"
https://xrdocs.io/telemetry/tutorials/2017-05-05-mdt-with-grpc-transport-tricks/
Sam
RP/0/RSP0/CPU0:ROU-00#bash
Tue Jun 24 08:40:16.341 ART
[ROU-00:~]$ netstat -r
Kernel IP routing table
Destination Gateway Genmask Flags MSS Window irtt Iface
default * 0.0.0.0 U 0 0 0 fwdintf
172.31.255.254 * 255.255.255.255 UH 0 0 0 fwd_ew
I have a loopback 0 configured so no need for setting source on tpa as the article describes.
That was one of the first things i've tried. Set up a new interface with a new network connected a laptop and the exact same thing happened. I dont know if it helps but the test and de collector are both connected through a nv satellite.
As a side note model driven dial out mode works just fine
Try this
Control-plane
Management-plane
Inband
Interface all
Allow all
MHM
Applied, no luck.
Can I see
show tcp brief
When you direct connect abd when you not direct connect
MHM
show tcp brief in 7.9.21 does not list grpc open ports. I have to bash and ss -punta to get this:
From the collector I see nothing
[ROU-00:~]$ ss -punta
Netid State Recv-Q Send-Q Local Address:Port Peer Address:Port
tcp LISTEN 0 128 :::57400 :::*
This connection is from second xr device (the one that works)
tcp LISTEN 0 128 :::57400 :::* users:(("emsd",pid=9079,fd=561))
tcp ESTAB 0 0 ::ffff:10.1.200.1:57400 ::ffff:10.27.220.2:42212
Show grpc
Can you share this
MHM
RP/0/RSP0/CPU0:ROU-00#show grpc
Tue Jun 24 17:53:10.392 ART
Address family : dual
Port : 57400
DSCP : Default
TTL : 64
VRF : global-vrf
Server : enabled
TLS : disabled
TLS mutual : disabled
Trustpoint : none
Certificate Authentication : disabled
TLS v1.0 : disabled
Maximum requests : 128
Maximum requests per user : 10
Maximum streams : 32
Maximum streams per user : 32
TLS cipher suites
Default : none
Enable : none
Disable : none
Operational enable : none
Operational disable : none
