'qos_ea' detected the 'fatal' condition 'Hw programming car entry failed'
Rojer-bkk
Hi Expert,
I cannot commit qos policy under bundle ethernet interface and got error message  'qos_ea' detected the 'fatal' condition 'Hw programming car entry failed'. Could it be bug CSCts66753. I use CRS1/ 4.0.1 Thanks
5 Replies 5
Ivan Krimmel
Level 7
Level 7
Hi Rojer,
though you have pointed out a good match, please keep in mind that MSC supports up to 16 Gbps policing per line card - so if you have a bundle with multiple 10 GE ports, you could potentially arrive at this situation, which will then generate the error message and not apply the policy.
HTH,
Ivan.
Hi Ivan,
If I configured bundle 4x10GE ports into bundle interface, the port member came from different line card slot so should i able to apply qos to bundle interface? (qos police bandwidth 40Gbps)
Hi Rojer,
thanks for the question, indeed, having bundle members splitted across different MSC's would be a solution if you want to achieve more than 16Gbps policing rate.
Cheers!
Ivan.
Hi Ivan,
Regarding MSC supports up to 16 Gbps policing per line card. Can i have document for reference?
Hi Rojer,
I checked the CCO and it looks like this information is not mentioned over there indeed. I will check around to see if we can have it posted on CCO as well.
HTH,
Ivan.
