show interface problem?
jiang-hui
when i use show interface command,can not see input rate and out rate,but i use show interface pos0/0/0/0 ,i can see it ,the CRS-1 version is 4.04,can someone help me?thanks!
RP/0/RP0/CPU0:FZ-QY-CR-1.MAN.CRS#show interfaces
POS0/0/0/0 is up, line protocol is up  (APS not Configured )
  Interface state transitions: 45
  Hardware is Packet over SONET/SDH
  Description: uT:JX-NC-RZ-D-1.163:(S-64N0001IP)::POS0/4/5/0
  Internet address is 220.177.46.66/30
  MTU 4474 bytes, BW 9953280 Kbit (Max: 9953280 Kbit)
     reliability Unknown, txload Unknown, rxload Unknown
  Encapsulation PPP, crc 32, controller loopback not set, keepalive set (10 sec)
  LCP Open
  Open: IPCP, IPv6CP
  Last input 00:00:00, output 00:00:00
  Last clearing of "show interface" counters 00:32:07
     1057794346 packets input, 797824535872 bytes, 0 total input drops
     0 drops for unrecognized upper-level protocol
     Received 0 runts, 0 giants, 0 throttles, 0 parity
     0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
     945088926 packets output, 665802983937 bytes, 0 total output drops
     0 output errors, 0 underruns, 0 applique, 0 resets
POS0/0/1/0 is up, line protocol is up  (APS not Configured )
  Interface state transitions: 321
  Description: uT:JX-NC-ECL-D-3.163:(S-64N0008IP)
  Internet address is 111.74.147.194/30
  Encapsulation HDLC, crc 32, controller loopback not set, keepalive set (10 sec)
     1416846640 packets input, 1082644803757 bytes, 0 total input drops
     1213762552 packets output, 838445403585 bytes, 0 total output drops
GigabitEthernet0/0/2/0 is up, line protocol is up
  Interface state transitions: 17
  Hardware is GigabitEthernet, address is a493.6c50.2521 (bia a493.6c50.2521)
  Description: T:FZ-QY-SR12416.MAN:GE6/0/3
  Internet address is 111.74.147.173/30
  MTU 1562 bytes, BW 1000000 Kbit (Max: 1000000 Kbit)
  Encapsulation ARPA,
  Full-duplex, 1000Mb/s, LX, link type is force-up
  output flow control is off, input flow control is off
  loopback not set,
  ARP type ARPA, ARP timeout 04:00:00
  Last clearing of "show interface" counters 00:32:04
     2425695 packets input, 629935421 bytes, 0 total input drops
     32 drops for unrecognized upper-level protocol
     Received 0 broadcast packets, 807 multicast packets
     30722838 packets output, 24265379146 bytes, 0 total output drops
     Output 0 broadcast packets, 981 multicast packets
     0 carrier transitions
RP/0/RP0/CPU0:FZ-QY-CR-1.MAN.CRS#show interfaces poS 0/0/0/0
Sun Jan 18 23:00:00.584 GMT
     reliability 255/255, txload 70/255, rxload 78/255
  LCP Open
  Open: IPCP, IPv6CP
  Last clearing of "show interface" counters 00:34:45
  30 second input rate 3060563000 bits/sec, 507914 packets/sec
  30 second output rate 2740646000 bits/sec, 485851 packets/sec
     1138830838 packets input, 859195648393 bytes, 0 total input drops
     1021839552 packets output, 719804461281 bytes, 0 total output drops
RP/0/RP0/CPU0:FZ-QY-CR-1.MAN.CRS#show version
Sun Jan 18 23:00:07.425 GMT
Cisco IOS XR Software, Version 4.0.4[Default]
Copyright (c) 2012 by Cisco Systems, Inc.
ROM: System Bootstrap, Version 2.05(20110622:151317) [CRS ROMMON],
FZ-QY-CR-1.MAN.CRS uptime is 2 years, 12 weeks, 3 days, 13 hours, 0 minutes
System image file is "disk0:hfr-os-mbi-4.0.4.CSCtz33725-1.0.0/0x100008/mbihfr-rp-x86e.vm"
cisco CRS-16/S-B (Intel 686 F6M14S4) processor with 6291456K bytes of memory.
Intel 686 F6M14S4 processor at 2135Mhz, Revision 2.174
CRS 16 Slots Line Card Chassis for CRS-16/S-B
2 Management Ethernet
14 SONET/SDH
14 Packet over SONET/SDH
14 WANPHY controller(s)
31 TenGigE
103 GigabitEthernet
1019k bytes of non-volatile configuration memory.
15801M bytes of hard disk.
11223024k bytes of disk0: (Sector size 512 bytes).
11223024k bytes of disk1: (Sector size 512 bytes).
jiang-hui
I find the bug:
interface rate counters pps missing from <show int>
CSCtr40734
Symptom:
On CRS system with new PRP, show interface will not display the rate for physical interface.
Workaround:
You can use
show interface *
or
sh interface _interface_name_
Jiang, good find, that is indeed the bug that you're running into.
this is fixed in 4.1.2 onwards.
Note that in general it is better to do a show interface <IF> to limit the amount of sysdb work needed in high interface running devices, but it should work obviously.
cheers
xander
