SNMP Trap modules and env
yansenyansen
I would like to know what the equivalent command to enable snmp traps module and env in IOS XR.
The IOS command is like below :
snmp-server   enable traps module
snmp-server enable traps envmon fan shutdown supply temperature status
i could not find similar command in IOS XR. is it the same with "snmp-server traps system" in IOS XR ?
rrahul
The equivalent command would be to configure "snmp-server traps fru-ctrl". Configuring this command should enable the router to send cefcPowerStatusChange and cefcModuleStatusChange traps.
Configuring SNMP on XR,
http://www.cisco.com/en/US/docs/ios_xr_sw/iosxr_r3.7/system_management/command/reference/yr37snmp.html
Thanks and regards,
Rahul.
rrahul
Thanks and regards,
Rahul.
Hi Rahul,
Thanks for information.
does "snmp-server traps fru-ctrl" include tempature trap ?
Hey,
You will need to configure "snmp-server traps sensor" to enable the traps under the CISCO-ENTITY-SENSOR-MIB. You can use the following docs to check whether these are supported on your XR platform.
For ASR9k, (table 3-2 lists the supported Traps on the ASR9k),
http://www.cisco.com/en/US/docs/routers/asr9000/mib/guide/asr9kmib3.html#wp1602338
For the GSR XR,
ftp://ftp.cisco.com/pub/mibs/supportlists/xr12000/xr12000-supportlist.html
For the CRS-1,
ftp://ftp.cisco.com/pub/mibs/supportlists/crs1/crs1-supportlist.html
Thanks and regards,
Rahul.
Hi Rahul,
Besides polling CPU MIBs, is there a trap (able to send notification to a server) in IOS XR for CPU utilization? Like snmp-server enable traps cpu in IOS
Thanks and regards,
