取消
显示结果
搜索替代
您的意思是:
查看次数
有帮助
回复
9971注册成功了,但是不能拨号为什么???
chrischi
在吗 我在测试9971的时候出现了一个 问题,就是我们的9971电话注册到我的CME上面,9971电话不能拨打统一个site的另一门也是注册到CME上的电话(7965),我电话的fireware是9971-9-4-1-9,是的CME的版本是15.2(4),能不能帮我解决下,我的邮箱是[email]1527073391@qq.com
chrischi: 这个是我CME的配置
r3#sh run
Building configuration...
Current configuration : 4297 bytes
! Last configuration change at 12:43:20 UTC Mon Feb 9 2015
version 15.2
hostname r3
boot-start-marker
boot-end-marker
! card type command needed for slot/vwic-slot 0/0
no aaa new-model
memory-size iomem 20
ip dhcp excluded-address 142.102.66.1 142.102.66.30
ip dhcp excluded-address 142.102.66.51 142.102.66.254
ip dhcp pool abc
network 142.102.66.0 255.255.255.0
default-router 142.102.66.254
option 150 ip 142.102.66.254
no ip domain lookup
ip domain name cciecollab.cisco.com
ip cef
no ipv6 cef
voice-card 0
voice-service dsp-reservation 40
dspfarm
dsp services dspfarm
voice service voip
allow-connections sip to sip
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
sip
bind control source-interface GigabitEthernet0/0.502
bind media source-interface GigabitEthernet0/0.502
registrar server
voice register global
mode cme
source-address 142.102.66.254 port 5060
timeouts interdigit 3
max-dn 10
max-pool 2
timezone 42
date-format D/M/Y
voicemail 4220
create profile sync 0002475233450008
camera
video
voice register dn 1
number 4002
call-forward b2bua busy 4220
call-forward b2bua noan 4220 timeout 20
mwi
voice register pool 1
id mac 10BD.1801.8FB1
type 9971
number 1 dn 1
description +85224044002
license udi pid CISCO2901/K9 sn FGL16192138
license accept end user agreement
license boot module c2900 technology-package uck9
hw-module ism 0
hw-module pvdm 0/0
file privilege 0
redundancy
interface Loopback0
ip address 142.1.66.254 255.255.255.255
interface Embedded-Service-Engine0/0
no ip address
shutdown
no ip address
duplex auto
speed auto
encapsulation dot1Q 502
ip address 142.102.66.254 255.255.255.0
interface GigabitEthernet0/0.602
encapsulation dot1Q 602
ip address 142.202.66.254 255.255.255.0
interface ISM0/0
ip unnumbered GigabitEthernet0/0.502
service-module ip address 142.102.66.253 255.255.255.0
!Application: CUE Running on ISM
service-module ip default-gateway 142.102.66.254
interface GigabitEthernet0/1
ip address 156.26.201.2 255.255.255.0
duplex auto
speed auto
interface ISM0/1
description Internal switch interface connected to Internal Service Module
no ip address
interface Vlan1
no ip address
router ospf 1
router-id 3.3.3.3
network 0.0.0.0 255.255.255.255 area 0
ip forward-protocol nd
ip http server
no ip http secure-server
ip http path flash1:/GUI
ip route 142.102.66.253 255.255.255.255 ISM0/0
control-plane
mgcp profile default
sccp local Loopback0
sccp ccm 142.102.66.254 identifier 1 priority 1 version 7.0
sccp
sccp ccm group 1
associate ccm 1 priority 1
associate profile 1 register SC-XCD
dspfarm profile 1 transcode
codec g729abr8
codec g729ar8
codec g711alaw
codec g711ulaw
codec ilbc
maximum sessions 4
associate application SCCP
dial-peer voice 4220 voip
description 4220
session protocol sipv2
session target ipv4:142.102.66.253
dtmf-relay sip-kpml rtp-nte
codec g711ulaw
no vad
sip-ua
mwi-server ipv4:142.102.66.253 expires 3600 port 5060 transport udp unsolicited
gatekeeper
shutdown
telephony-service
sdspfarm units 5
sdspfarm transcode sessions 6
sdspfarm tag 1 SC-XCD
max-ephones 2
max-dn 10
ip source-address 142.102.66.254 port 2000
time-zone 42
voicemail 4220
max-conferences 8 gain -6
transfer-system full-consult
secondary-dialtone 9
ephone-dn 1
number 4001
description +85224044001
call-forward busy 4220
call-forward noan 4220 timeout 20
ephone 1
mac-address 0023.EBC6.F647
type 7965
button 1:1
line con 0
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line 67
no exec
transport input all
stopbits 1
line vty 0 4
login
transport input all
scheduler allocate 20000 1000
end
1 个已接受解答
已接受的解答
zhaowang
抓一下debug吧
debug voice ccapi inout
debug ccsip message
另外打不通是什么症状?忙音?
在原帖中查看解决方案
5 条回复5
zhaowang
抓一下debug吧
debug ccsip message
另外打不通是什么症状?忙音?
chrischi
zhaowang 发表于 2015-3-3 16:56 back.gif
抓一下debug吧
debug ccsip message
现象就是7965的电话打9971,9971可以正常接的,但是9971的电话打7965,我在9971上拨号了但是没有反应,然后过来大约很长时间就嘟嘟嘟了,7965和9971都是注册到同一个CME路由器上面的,属于同一个site,电话我也换过了 不是电话问题,电话的fireware我也换了也不行,CME版本查过了全都支持的,所以很无奈?
chrischi
抓一下debug吧
debug ccsip message
如果是忙音的话这么解决呀
Yanli Sun
Community Manager
Community Manager
您好,已经有人回复您的问题了,不知您的问题是否已经得到满意答复,如果是请您选择“已解决”,感谢您的支持~~~
chrischi
chrischi 发表于 2015-3-16 19:01 back.gif
如果是忙音的话这么解决呀
没有任何logging信息 但是9971电话注册成功了
快捷链接
