如题,CallManager 设置某部IP Phone Call Forward的时候,发现内部电话打被转接Phone是可以的,但是外部电话打被转接Phone的时候会出现呼叫受限,Voice Gateway上出现如下所示:
May 15 05:37:25.658: ISDN Se0/0/0:15 Q931: RX <- SETUP pd = 8 callref = 0x00BA
Sending Complete
Bearer Capability i = 0x8090A3
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA1839E
Preferred, Channel 30
Calling Party Number i = 0x2183, '18115661051'
Plan:ISDN, Type:National
Called Party Number i = 0xC1, '66057260'
Plan:ISDN, Type:Subscriber(local)
May 15 05:37:25.658: ISDN Se0/0/0:15 Q931: Received SETUP callref = 0x80BA callID = 0x0199 switch = primary-net5 interface = User
May 15 05:37:25.662: ISDN Se0/0/0:15 Q931: TX -> CALL_PROC pd = 8 callref = 0x80BA
Channel ID i = 0xA9839E
Exclusive, Channel 30
May 15 05:37:25.662: ISDN Se0/0/0:15 Q931: TX -> CONNECT pd = 8 callref = 0x80BA
May 15 05:37:25.722: ISDN Se0/0/0:15 Q931: RX <- CONNECT_ACK pd = 8 callref = 0x00BA
May 15 05:37:45.949: ISDN Se0/0/0:15 Q931: Applying typeplan for sw-type 0x12 is 0x2 0x1, Calling num 18115661051
May 15 05:37:45.949: ISDN Se0/0/0:15 Q931: Sending SETUP callref = 0x02C4 callID = 0x8245 switch = primary-net5 interface = User
May 15 05:37:45.949: ISDN Se0/0/0:15 Q931: TX -> SETUP pd = 8 callref = 0x02C4
Standard = CCITT
Channel ID i = 0xA9839F
Exclusive, Channel 31
Calling Party Number i = 0x2181, '18115661051'
Called Party Number i = 0x80, '13382105238'
Plan:Unknown, Type:Unknown
May 15 05:37:46.005: ISDN Se0/0/0:15 Q931: RX <- RELEASE_COMP pd = 8 callref = 0x82C4
Cause i = 0x8295 - Call rejected
May 15 05:37:46.013: ISDN Se0/0/0:15 Q931: Applying typeplan for sw-type 0x12 is 0x2 0x1, Calling num 18115661051
May 15 05:37:46.013: ISDN Se0/0/0:15 Q931: Sending SETUP callref = 0x02C5 callID = 0x8246 switch = primary-net5 interface = User
May 15 05:37:46.013: ISDN Se0/0/0:15 Q931: TX -> SETUP pd = 8 callref = 0x02C5
Sending Complete
Standard = CCITT
Called Party Number i = 0xC1, '1183320087260'
May 15 05:37:46.045: ISDN Se0/0/0:15 Q931: RX <- CALL_PROC pd = 8 callref = 0x82C5
May 15 05:37:46.077: ISDN Se0/0/0:15 Q931: RX <- PROGRESS pd = 8 callref = 0x82C5
Cause i = 0x829F - Normal, unspecified
Progress Ind i = 0x8288 - In-band info or appropriate now available
“ Calling Party Number i = 0x2183, '18115661051'
‘11833200’这个是IP 电话呼叫模拟电话是添加的前缀,不知道为什么会在呼叫转接中被匹配到?
