取消
显示结果
搜索替代
您的意思是:
查看次数
有帮助
回复
CallManager 10.5.1 Call Forward
jing zhang
如题,CallManager 设置某部IP Phone Call Forward的时候,发现内部电话打被转接Phone是可以的,但是外部电话打被转接Phone的时候会出现呼叫受限,Voice Gateway上出现如下所示:
May 15 05:37:25.658: ISDN Se0/0/0:15 Q931: RX <- SETUP pd = 8 callref = 0x00BA
Sending Complete
Bearer Capability i = 0x8090A3
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA1839E
Preferred, Channel 30
Calling Party Number i = 0x2183, '18115661051'
Plan:ISDN, Type:National
Called Party Number i = 0xC1, '66057260'
Plan:ISDN, Type:Subscriber(local)
May 15 05:37:25.658: ISDN Se0/0/0:15 Q931: Received SETUP callref = 0x80BA callID = 0x0199 switch = primary-net5 interface = User
May 15 05:37:25.662: ISDN Se0/0/0:15 Q931: TX -> CALL_PROC pd = 8 callref = 0x80BA
Channel ID i = 0xA9839E
Exclusive, Channel 30
May 15 05:37:25.662: ISDN Se0/0/0:15 Q931: TX -> CONNECT pd = 8 callref = 0x80BA
May 15 05:37:25.722: ISDN Se0/0/0:15 Q931: RX <- CONNECT_ACK pd = 8 callref = 0x00BA
May 15 05:37:45.949: ISDN Se0/0/0:15 Q931: Applying typeplan for sw-type 0x12 is 0x2 0x1, Calling num 18115661051
May 15 05:37:45.949: ISDN Se0/0/0:15 Q931: Sending SETUP callref = 0x02C4 callID = 0x8245 switch = primary-net5 interface = User
May 15 05:37:45.949: ISDN Se0/0/0:15 Q931: TX -> SETUP pd = 8 callref = 0x02C4
Standard = CCITT
Channel ID i = 0xA9839F
Exclusive, Channel 31
Calling Party Number i = 0x2181, '18115661051'
Called Party Number i = 0x80, '13382105238'
Plan:Unknown, Type:Unknown
May 15 05:37:46.005: ISDN Se0/0/0:15 Q931: RX <- RELEASE_COMP pd = 8 callref = 0x82C4
Cause i = 0x8295 - Call rejected
May 15 05:37:46.013: ISDN Se0/0/0:15 Q931: Applying typeplan for sw-type 0x12 is 0x2 0x1, Calling num 18115661051
May 15 05:37:46.013: ISDN Se0/0/0:15 Q931: Sending SETUP callref = 0x02C5 callID = 0x8246 switch = primary-net5 interface = User
May 15 05:37:46.013: ISDN Se0/0/0:15 Q931: TX -> SETUP pd = 8 callref = 0x02C5
Sending Complete
Standard = CCITT
Called Party Number i = 0xC1, '1183320087260'
May 15 05:37:46.045: ISDN Se0/0/0:15 Q931: RX <- CALL_PROC pd = 8 callref = 0x82C5
May 15 05:37:46.077: ISDN Se0/0/0:15 Q931: RX <- PROGRESS pd = 8 callref = 0x82C5
Cause i = 0x829F - Normal, unspecified
Progress Ind i = 0x8288 - In-band info or appropriate now available
“ Calling Party Number i = 0x2183, '18115661051'
‘11833200’这个是IP 电话呼叫模拟电话是添加的前缀,不知道为什么会在呼叫转接中被匹配到?
1 个已接受解答
已接受的解答
csco11543423
thousandmoun 发表于 2015-5-21 20:46 back.gif
应该不是这么理解,
最后的问题是应该是缺少了一个主叫号码出局,
我明白你的意思就是在呼出的dial-peer上送重定向的号码+called和Calling号码,很多运营商是不看这消息的,他只认Calling出来的号码必须是你购买的号码段就行了。(如果运营商识别你的消息后,就出现了透传号码,现在不提供了)
可能某些地方电信还可以用.
在原帖中查看解决方案
5 条回复5
csco11543423
应该不是这么理解,
可能某些地方电信还可以用.
jing zhang
在呼出规则中添加一条默认rule就可以了;
Xingxing Zhang
Call Forward 配置了可以呼出外线的CSS了吧?
csco11543423
你的这个问题
1、某一写电信不允许Calling Number透传出局,H323或者MGCP网关的Outbound Calls方向的Calling Party设置为First Redirect Number
2、你的FWD后的号码加了11833200写一个转换规则吃掉就行了
jing zhang
csco11543423 发表于 2015-5-20 12:05 back.gif
你的这个问题
1、某一写电信不允许Calling Number透传出局,H323或者MGCP网关的Outbound Calls方向的Calli ...
应该不是这么理解,
至于prefix的问题,我做的是一条dial-peer,在内部IP电话拨8开头的号码的时候,在号码前面加一个prefix,这样电信就可以识别并转到相应的虚拟电话;
快捷链接
