取消
显示结果
搜索替代
您的意思是:
查看次数
有帮助
回复
SDWAN L2 LAN port
wl0684913
We are planning to migrate our DWAN system to SDWAN.
Currently we are using hardware C1111-8P which supports SDWAN and two MPLS circuit and use L2 port as the LAN port.
This device only has two L3 ports(and all connect to WAN), if I move to SDWAN can I still use the L2 port as a LAN port and use the vlan to establish OSPF with Core switch?
1 条回复1
balaji.bandi
yes you can use high level as you mentioned, you can also make sub-interface if you have short of ports (hope that help you)
BB
快捷链接
