취소
다음에 대한 결과 표시
다음에 대한 검색
다음을 의미합니까?
VIEWS
답글
IE Switch 4000 GUI Inaccessible
gunheon103
IE-4000-4GS8GP4G-E
version 15.2
no service pad
hostname Switch
boot-start-marker
boot-end-marker
username admin password 0 admin
no aaa new-model
system mtu routing 1500
ip routing
vtp mode transparent
spanning-tree mode rapid-pvst
alarm profile defaultPort
alarm not-operating
syslog not-operating
notifies not-operating
vlan internal allocation policy ascending
vlan 10,20,40,115,175,300
interface GigabitEthernet1/1
switchport access vlan 10
switchport mode access
interface GigabitEthernet1/2
interface GigabitEthernet1/3
interface GigabitEthernet1/4
interface GigabitEthernet1/5
interface GigabitEthernet1/6
interface GigabitEthernet1/7
interface GigabitEthernet1/8
interface GigabitEthernet1/9
interface GigabitEthernet1/10
interface GigabitEthernet1/11
interface GigabitEthernet1/12
interface GigabitEthernet1/13
interface GigabitEthernet1/14
interface GigabitEthernet1/15
interface GigabitEthernet1/16
interface Vlan1
ip address 192.168.115.104 255.255.255.0
interface Vlan10
ip address 192.168.1.254 255.255.255.0
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
line con 0
line vty 0 4
exec-timeout 20 0
login local
transport input ssh
line vty 5 15
exec-timeout 20 0
login local
transport input ssh
위와 같은 설정을 했는데 GUI / https / https 으로 접근이 불가능하다. 화면이 안뜹니다.
I made the above settings, but I can't access them with GUI / https / https. The screen won't pop up.
Ping test normal
참고자료 / reference
https://www.cisco.com/c/en/us/products/collateral/switches/industrial-ethernet-4000-series-switches/datasheet-c78-733058.html
https://www.cisco.com/c/en/us/td/docs/switches/lan/cisco_ie4000/Connexa/Software/configuration/guide/b_IOx_IE4k.ht
case open ?
2 채택된 솔루션
채택된 솔루션
Translator
Community Manager
Community Manager
추가 정보 감사합니다. show version의 부분 출력에는 실행 중인 코드의 특정 버전(도움이 될 수도 있는 내용)에 대한 정보가 포함되어 있지 않습니다.  명령어 dir flash: 에 대한 아웃풋이 도움이 될 것 같습니다.
제 생각에는 "Device Manager Package : None"이 중요하다고 생각합니다.
원본 게시물의 솔루션 보기
Translator
Community Manager
Community Manager
dir flash: 의 출력에 감사드립니다. 일부 파일이 보이지 않습니다. 이는 Device Manager Package(디바이스 관리자 패키지): None(없음) 및 GUI가 작동하지 않는 이유에 대한 설명이 될 수 있습니다.
원본 게시물의 솔루션 보기
11 응답 11
Translator
Community Manager
Community Manager
커뮤니티 리소스를 사용하여 귀하의 문제를 해결하도록 도와드리겠습니다. Cisco TAC에서 케이스를 열 수 있다면 다행입니다. 이들은 Community에 없는 리소스에 액세스할 수 있습니다.
게시된 구성은 간단합니다. VLAN 1 및 VLAN 10에 할당된 포트가 있습니다(다른 VLAN이 표시되지만 포트는 할당되지 않았으므로 이 시점에서는 작동하지 않음). Post에서는 ping 테스트가 정상이므로 디바이스 간에 HTTP/HTTPS 액세스를 시도하는 IP 연결이 있다고 가정합니다. 그러나 HTTP/HTTPS가 작동하지 않습니다. 그래서 우리는 더 자세히 조사할 필요가 있습니다. 다음 명령에 대한 아웃풋을 알려주세요요.
show version
dir flash:
이 스위치는 새로 설치한 건가요, 아니면 그동안 작동한 건가요? 이 스위치가 코드를 업그레이드했을 가능성이 있나요? HTTP/HTTPS가 작동하려면 일부 HTML 파일에 액세스할 수 있어야 합니다. 패키지 파일이 아닌 bin 파일을 사용하여 스위치가 새로운 버전으로 업그레이드된 상황을 본 적이 있습니다. 이 경우 현재 실행 중인 버전에 HTML 파일이 없으며 HTTP/HTTPS가 작동하지 않습니다. 그게 이 케이스일지 궁금하군요
512K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address :
Motherboard assembly number :
Motherboard serial number :
Model revision number : K0
Motherboard revision number : A0
Model number : IE-4000-4GS8GP4G-E
System serial number :
Top Assembly Part Number :
Top Assembly Revision Number : K0
Version ID : V01
Hardware Board Revision Number : 0x05
Backplane FPGA version : 0.57
Feature Mode : 0x2D Enabled: MRP (Disabled: TSN HSR)
CIP Serial Number :
SKU Brand Name : Cisco
위에 Device Manager Packge : None ? Device Manager Package : Multi-language ?
Can't I do it when it's "None?
Although the GUI is approaching, it doesn't appear in the web page.
It was inaccessible from the beginning and did not upgrade the OS. Thank you.
Translator
Community Manager
Community Manager
Above is a dir mark.
The normal switch is marked Device Manager Package : Multi-language, and I think the GUI is not working properly because of the None state.
Directory of flash:/
2 drwx 1024 Dec 10 1914 07:07:43 +00:00 ie4000-universalk9-mz.152-8.E1
1900 drwx 512 Mar 30 2011 01:55:23 +00:00 dc_profile_dir
1902 -rwx 41 Jul 26 2018 02:15:24 +00:00 syncsetup.txt
1903 drwx 512 Mar 30 2011 01:28:26 +00:00 pnp-tech
1906 drwx 512 Mar 30 2011 01:27:59 +00:00 managed
1914 -rwx 46604 Mar 30 2011 03:11:18 +00:00 pnap.dat
1915 drwx 512 Mar 30 2011 01:27:59 +00:00 eem
1916 drwx 512 Mar 30 2011 01:28:00 +00:00 pnp-info
1917 -rwx 35822 Mar 30 2011 07:43:37 +00:00 nms.odm
1918 -rwx 3174 Mar 30 2011 01:30:17 +00:00 backup-config
1919 -rwx 616 Mar 31 2011 03:20:45 +00:00 vlan.dat
1920 -rwx 2642 Mar 31 2011 04:10:20 +00:00 config.text
1922 -rwx 1921 Oct 27 2023 05:06:17 +00:00 private-config.text
1923 -rwx 8216 Oct 27 2023 05:06:17 +00:00 multiple-fs
Translator
Community Manager
Community Manager
I checked the dir file of a normal IE switch, but it is the same.
2 drwx 1024 Aug 29 2023 01:26:10 +00:00 ie4000-universalk9-mz.152-8.E1
1911 drwx 512 Aug 29 2023 01:26:10 +00:00 dc_profile_dir
1913 -rwx 4583 Mar 30 2011 05:53:32 +00:00 config.text
1914 -rwx 736 Mar 30 2011 05:53:32 +00:00 vlan.dat
1915 -rwx 41 Aug 29 2023 01:43:54 +00:00 syncsetup.txt
1916 drwx 512 Mar 30 2011 01:27:59 +00:00 pnp-info
1917 -rwx 46604 Mar 30 2011 05:53:33 +00:00 pnap.dat
1918 drwx 512 Mar 30 2011 01:28:58 +00:00 pnp-tech
1921 drwx 512 Aug 29 2023 01:46:42 +00:00 managed
1929 drwx 512 Aug 29 2023 01:46:42 +00:00 eem
1930 -rwx 9240 Mar 31 2011 05:15:58 +00:00 multiple-fs
1931 -rwx 35822 Mar 30 2011 02:34:48 +00:00 nms.odm
1932 -rwx 1915 Mar 31 2011 05:15:58 +00:00 private-config.text
Translator
Community Manager
Community Manager
업데이트해 주셔서 감사합니다. 두 스위치의 dir 플래시가 같은 파일을 가지고 있는 것처럼 보입니다. 따라서 제가 예상하는 일부 파일을 보지 못하는 것에 대한 저의 의견은 아마도 다른 Cisco 스위치 모델과의 경험 때문일 것입니다. 이 모델은 이전에 작업한 적이 없으며, 분명히 다른 파일 구조를 사용합니다.
이 스위치에서 로깅을 활성화했습니까? GUI를 사용하여 액세스를 시도하는 경우 스위치에서 메시지를 생성했는지 확인할 수 있습니까?
이 문제가 해결됨으로 표시된 이유를 알 수 없습니다. 펌웨어 버전 15.2(8)의 여러 스위치에서 이 문제가 발견되었습니다. 이전 펌웨어 15.2(5)를 로드하면 문제가 해결되므로 이 펌웨어와 관련된 것으로 의심됩니다. 나는 이것을 알려진 버그로 보여주는 어떤 것도 찾지 못했습니다. 만약 여전히 이 문제를 해결하려고 한다면 my .02 만 있으면 됩니다.
Yes, I haven't solved it since then and I'm going to upgrade the firmware. Thank you.
빠른 링크
