취소
다음에 대한 결과 표시
다음에 대한 검색
다음을 의미합니까?
VIEWS
답글
Regarding Network-Advantage License
김선명
Hi~
I am writing to learn more about Cisco's licensing policy.
I understand that when purchasing Cisco equipment, it is mandatory to also purchase a DNA license (for 3, 5, or 7 years).
1. If I purchase DNA-Essentials, can I only use Network Essentials?
2. Can I use Network-Advantage only if I purchase DNA-Advantage?
1 채택된 솔루션
채택된 솔루션
balaji.bandi
1. If I purchase DNA-Essentials, can I only use Network Essentials?  - YES Correct you are entitled  get that features part of the License.
2. Can I use Network-Advantage only if I purchase DNA-Advantage?  - YES correct and you also get lower License Levels.
FYI
BB
원본 게시물의 솔루션 보기
5 응답 5
balaji.bandi
FYI
BB
@balaji.bandi Thank you for your quick reply.
What happens if I force upload to Network-Advantage via command in Network Essentials?
Nothing happends, if you have License you are entitled to use and the device work as expected.
if not you get Trail License for 90days then you have compliance issue. (but when you change One tier to other, device need to reboot to get effected - example if you running essential want to network advantage, you need to reboot the device to take effective or new License)
Cat 9K are smart License by default.
BB
@balaji.bandi Thank you for your reply.
Let's assume that after changing to network-advantage, we reboot.
Then I understand that it will be used as RTU and there may be compliance issues.
Is this correct?
Translator
Community Manager
Community Manager
BGP를 사용하도록 디바이스 두 개를 업그레이드하려고 합니다. 90 평가판이 끝날 때 BGP가 작동을 멈추는 것은 무엇입니까?
감사합니다.
크리스
빠른 링크
