Dimensions of the Bracket for wall mounting of PTZ 4K camera
hirotaka1215
Hello.
I'm looking for a document that shows the dimensions of the Bracket for wall mounting of PTZ 4K camera (CS-PTZ4K-BRKT =).
I can't find it. If There are any materials such as CAD drawings, would you please share them?
Specifically, I would like to know the size of the screw holes and the spacing between the screw holes for mounting on the wall .
Best Regards,
Hirotaka Kato
hirotaka1215
Hello, everyone
I asked for our local Cisco engineer, and he provided the CAD for the blanket.
So I share it for you.
Thank you,
Hirotaka Kato
5 Replies 5
Ratheesh Kumar
I guess it depends on the mount bracket type you use. Below link shows the list and you can get the specs of each mode.
https://www.bhphotovideo.com/c/buy/ptz-camera-mounts/ci/24605/N/3907816615
Hope this Helps
Cheers
Rath!
***Please rate helpful posts and if applicable mark "Accept as a Solution"***
Thank you for reply,
I checked the link, but there is no information of the Bracket for wall mounting of PTZ 4K camera (CS-PTZ4K-BRKT =).
Thank you for reply!
But I`m looking for CAD drawing of "the Bracket for wall mounting", not the camera.
hirotaka1215
Hello, everyone
Thank you,
Hirotaka Kato
