03-20-2024 12:15 AM - edited 03-20-2024 12:16 AM
Hi All,
I have couple of Cisco Voice gateway in which we need to enable PRI Layer 2 status monitoring, if the PRI goes out of service we need an alert.
We are using Solarwinds as monitoring tool and found in some Cisco community discussion that this can be enabled using Custom polling with OID details.
Can anyone please help me with more details on this.Is the OID is different for different router models or for different Interfaces.
also let me know how I can get the OID details.
Solved! Go to Solution.
03-20-2024 01:48 AM
You may find the following thread useful Solved: Monitor PRI status - Page 2 - Cisco Community
I use the same concepts and I get alerts like the ones below
Disclaimer:
Responses are based on personal knowledge and experience. Consider them as guidance. Other members may offer different perspectives or better approaches. No responsibility is assumed for outcomes; discretion is advised.
03-20-2024 01:26 AM
You can get Cisco MIB from https://snmp.cloudapps.cisco.com/Support/SNMP/do/BrowseMIB.do?local=en&mibName=CISCO-POP-MGMT-MIB and isdn MIB from the link - https://www.activexperts.com/admin/mib/rfc/isdn-mib/
you should have the proper SNMP string and host configured in VG to get the access from your SNMP applications.
03-20-2024 01:48 AM
Disclaimer:
