🎧Q: How to connect a Cisco Headset 730 with an iPhone?🎧
davidfit
A: The first time you use the Cisco Headsets app and connect your 730 with an iPhone you will follow the steps shown in these pictures.
1. Allow Bluetooth and start scanning for your Cisco Headset 730
2. Select Cisco HS 730-xxx and press Continue. Note: xxx is the last 3 characters of your headset serial number
If you have previously connected a Cisco Headset 730 using the Cisco Headsets app, try the following:
1. Turn on the headset and hold the slider up for 3 seconds to put it into pairing mode. It is in pairing mode if the Bluetooth LED is flashing blue.
2. On the iPhone, open the Cisco Headsets app.
3. A Bluetooth pairing request should appear, if so, press Pair
 If not, press Retry a few times to see if the pairing request appears.
 5. If the error persists, consult the troubleshooting section for assistance (coming soon).
0 Replies 0
