How to disable “recommended messages”
jucrissm
How do I disable “recommended messages?” It don’t need or want it.
7 Replies 7
Go to Filter > and choose hide recommended messages.
MarioSierra
Hi @jucrissm
from which device are you using webex?
Igor Mitrovic
The most useless implementation in Teams ever.
neil wooloff
Open Settings
Click Messaging
untick (remove) the tick from the box titled; Show recommended messages
click Save
Thank you, but I don't even have that section within settings > messaging. All I have there is (1) Show Link Preview (2) Compress Files (3) Voice Clips (4) Archived Teams. This is from my mobile - iPhone 13 mini.
It's been long since you asked this question and you must have found a way to turn it off. If not, click on the menu button on the top right-hand side of the app window and untick "show recommended messages".
Ah ok, didn’t catch that bit.
I was on the desktop app and that’s all I use, sorry can’t help more than that.
