Less data when on the go.
I am not sure who out there has had the opportunity to use this feature, however I felt that it should be share and to give it a try as a user who is on the go and not always connected to WiFi, it is very useful.
By going to :
>Meeting setting
> Then toggle off Use Mobile Data for Video
By doing this it will save you data, so when you are in a different country or just out and about then the video streams will be limited.
No need to worry though, once you are back on WiFi all the videos will be back.
Has anyone tried this?
Alexandru Nitu
I tried this feature when I was in a different country, and yes, my video streams were limited. I think it's a useful feature when you want to keep your data limit. But I think in some cases, exists the possibility to forget this setting when you want to use all video streams whether you are on mobile data.
