Promote apps and bots better in Webex Teams
tharshan09
Hi there,
I just finished developing a bot for Webex Teams. However, I am worried that no one will discover it or find out about it because bots and apps are not discoverable within the Webex Teams client.
Currently, a user of WebEx Teams, has no idea that bots exist from the current UI of the clients, or how to add them.
As a developer on the platform, it would be really great if the platform can do its part to help and aid in discovery.
8 Replies 8
gabriela-webex
Sounds good!  I'd suggest to post this idea on the feature request page, https://ciscocollabcustomer.ideas.aha.io/ where will be reviewed and you will get notified of response and progress.
horacio.benedicto
In the configuration and setting options of a team space, there is one called "add applications".
If you click on it, it takes you to a page where you can choose hundreds of BOTs.
If the user is curious and researches, then he will find it.
If you want to publish your BOT, connect to Cisco.
I recommend you to take the course to get certified by Webex Ambassasdor.
When you are an Ambassador, then you have access to over 30 Teams spaces with many Cisco specialists.
Two spaces are exclusive on BOT development and Cisco APIs.
El hombre "NO ES", el hombre "ESTÁ" .... Y todos los estados son modificables.
The man "is not", the man "IS" ... and all states are modifiable
Aamacias1974
I want to create a bot in WebEx teams that does bulk uploads of users to a WebEx Teams Group. Have any experience with this?
rohmoham
HI - Do you mind if you could throw more light on the bot that you created? Interested to know.
I developed a bot called Scrumgenius. It helps teams run remote stand-ups
on cisco WebEx team. The platform helps surface blockers and tracks goals.
That's great to know, I am curious to know more on this, could we connect for few mins? you can ping me on Jabber or Spark - rohmoham.
I am having trouble reaching you through those means of communication. Please, can we connect through email? hello[at]scrumgenius.com
stgreenb
You can submit your work to https://apphub.webex.com/
