Using Slido for employee surveys?
hdhebar
Hi all, I'm keen to hear if anyone has had experiences and/ or learnings from using Slido as an employee survey tool?  Any sharable assets e.g. question library would be amazing, Thanks!
marpena2@cisco.com
If you have any webex integration questions, you can always search the webex help center at help.webex.com.
I hope the following link provides you value in creating a survey with Slido:
https://help.webex.com/en-US/article/qpvziw/Create-a-survey-in-Slido
Jarek Bosacki
I don't have a library but my strong recommendation would be to use as much as you can Slido for any type of the workshops that you are running. It definitely helps with audience engagements, collecting feedback, issues, problems etc.
I agree Jarek.  Using Slido as much as possible not only gets you used to its features, but will also let your meeting participants get used to it and the great functionality it can add to meetings.
