Webex Meetings Recording quality settings
Shambu Gad
How do i setup the webex meetings recording quality setting to 1080p ?
Cole Callahan
The Meeting recording should automatically be 1080p quality. You can check to make sure by right-clicking the download on your desktop and checking the properties of it. Are you recording it locally or on the cloud?
Response Signature
Cole Callahan
Response Signature
Thanks for the info. Customer was facing issue with the recording quality and wanted to check if there is any setting on control hub to set the recording quality to 1080p or even 2k or 4k to improve the playback quality.  They are recording on the cloud.
If you are interested in high quality recordings for trainings / messages you may also want to check out Cisco's new Vidcast product.  https://vidcast.io/
