ACI and Netflow
eugenia
Can an ACI fabric export netflow data and if so are there any configuration guides/examples?
dpita
Hello!
Thanks for using support forums!
Netflow support will be coming out in December/January timeframe. Look forward to some configuration documents then!
8 Replies 8
seems like not. They suggest to send traffic sampling using ERSPAN and then convert it into netflow.
Vladimir, Thank you for responding and confirming.  I was not sure that was still the case!
dpita
Hello!
milwrigh
It's Feb now...is NetFlow exports supported? If so, can you send link to docs?
Netflow configuration videos released on the ACI youtube channel this week:
Part 1 - https://www.youtube.com/watch?v=6Yl_GelaS7g
Part 2 - https://www.youtube.com/watch?v=LQCZdf9Sux0
scherrav
The Config guide for Netflow with ACI is out now
Please see
http://www.cisco.com/c/en/us/td/docs/switches/datacenter/aci/apic/sw/kb/b_KB_Cisco_APIC_and_NetFlow.html
H Scherrav,
What is the difference in between configuring a Fabric Netflow policy and Tenant Netflow policy? Is this supposed to configure both? or either one will suffice? And I am a bit confused on what is the purpose of EPG Type, Associated EPG and Associated VRF?
yan.peyer
Why do I have to set a /20 network for the source? Is there any other way to set a single /32 address?
apic1(config-tn-flow-exporter)# source address
inband-mgmt-ip oob-mgmt-ip ptep
apic1(config-tn-flow-exporter)# source address 1.1.1.1 ?
<CR>
Error: Source address can have a mask upto 20 and 116 for ipv4 and ipv6 addresses respectively
Command execution failed.
apic1(config-tn-flow-exporter)# source address 1.1.0.0/20
apic1(config-tn-flow-exporter)# no source address
