07-23-2019 10:49 AM
Why my EPG "Apache" from my Tenant PROD cannot communicate with my L3 OUT (RO) configured in my Tenant common ?
My EPG provide PING/HTTP contract (global shared) and my EN_L3_OUT consume it (consumed contract interface because its a import from Tenant Prod)
I can ping my L3 out from my Tenant COMMON but not from my Tenant PROD
I can ping SVI node profile leaf interface from COMMON and not from PROD.
Best regards
07-23-2019 06:10 PM
Hi Chris,
I am assuming your internal EPG and L3out are in 2 different tenants and VRFs as well.
Need you to check two things:
1. In external EPG (networks section) under L3 out config, can you please check if you have following tick marks enabled for external prefixes ---> "shared route control subnet" and "shared security import subnet" (by default, only one tick mark is enabled i.e. external subnets for external epg). Enable them if not already.
2. Do you have tick marks enabled for "advertised externally" and "shared between VRFs" for subnets under BD which is associated with "Apache" EPG in "PROD" tenant. Enable them if not already.
Often these are the knobs to check in a broken Shared L3out setup.
Best Regards,
Jayesh
***Rate all posts that are helpful. Mark it as a solution if that solves your problem, it may help other users who have the same query.***
07-24-2019 04:42 AM
Hi Jayesh,
-> IT's OK, all Tick are marked as enabled
-> IT's OK
I can't find my External Network IP in my VRF_PROD and also in my VRF_COMMON, I only see my SVI IP
I can ping my External EPG from VRF COMMON but not from VRF PROD
Externally, I found echo request echo reply from my EPG APACHE (thanks to tcpdum) when I ping from L3out computer but nI dont see echo reply. routing problem on VRF
Thanks for your help
07-25-2019 11:09 AM
Hi Chris,
You can refer to https://community.cisco.com/t5/data-center-documents/aci-inter-vrf-tenant-route-leaking-configuration-example/ta-p/3221879
Looks like you haven't configured the subnet under the provider EPG which is required. Other way would be to provide and consume the contract in EPG and external EPG.
-Ganesh
