APIC CLI command to find Hardware Model of Leaf/Spine
snarayanaraju
Level 4
Level 4
Hello - What is the CLI command that i can execute from the APIC to list down the Node Name and Hardware Model  of the Leaf and Spine connected in the Fabric.
The commands such as acidiag fnvread,  show switch shows only the IP, Node Name. It dont show the Model number
Can you help please
regards,Sairam
RedNectar
Is this what you are looking for? The fnvread command?
apic1# fnvread
        id               address  disabled    active  occupied permanent              model  nodeRole  nodeType  fabricId     podId
   1101(1)     10.1.120.65/32(1)     NO(0)    YES(1)    YES(1)    YES(1)      N9K-C9332C(1)      3(1)      0(1)      1(1)      1(1)
   1201(1)     10.1.120.64/32(1)     NO(0)    YES(1)    YES(1)    YES(1) N9K-C93180YC-FX(1)      2(1)      0(1)      1(1)      1(1)
   1202(1)     10.1.120.66/32(1)     NO(0)    YES(1)    YES(1)    YES(1) N9K-C93180YC-FX(1)      2(1)      0(1)      1(1)      1(1)
It does not list the NAME though, just the ID. To get the Name as well, use moquery
apic1# moquery -c fabricNode | egrep "^id|^model|^name "
model : N9K-C93180YC-FX
model : N9K-C9332C
model : APIC-SERVER-M3
That catches the APICs as well
I hope this helps
Don't forget to mark answers as correct if it solves your problem. This helps others find the correct answer if they search for the same problem
RedNectar aka Chris Welsh.
balaji.bandi
below command should able to get the information you looking
#show version
#avread
# moquery
BB
Thank you. Much appreciated
RedNectar
apic1# fnvread
model : N9K-C9332C
I hope this helps
Thank You Very much
