06-28-2017 07:46 AM - last edited on 03-25-2019 01:21 PM by ciscomoderator
Having challenge is Discovering the nodes. After multiple reboot of ACI & Leaf I managed to register a directly connected leaf. However it took more than an hour to get IP address. Now registered Spine but discovery in progress for almost an hour.
During initial reboot I disabled POAP in the nodes. Is it causing issue? Is there a way to enable the POAP in the nodes.
ACI version 2.1.1h
Thanks in advance for taking your time to reply!
Solved! Go to Solution.
06-30-2017 05:59 AM
The time difference between the APIC and the Leaf\Spine node may be the issue.
As Admin User, the steps are:
Note: you are only setting the "running system clock" not the hardware clock. you will need to sync the "running system clock" to the hardware clock to be persistent after a reload of the Leaf\Spine node.
I hope this helps!
T.
06-29-2017 07:35 AM
POAP is not used on N9K Switched running in ACI mode. If you see the switches trying to use POAP then they are still in NXOS mode.
There can be various reasons why a node may not be discovered. One of the common issues is that the Date & Time are considerably out of sync with the APIC controllers.
We would be just guessing without looking at the fabric itself. If you are in a lab (non-production) environment and are just setting up fabric:
If this goes smoothly, then you should be fine. Otherwise, if you continue experience issues please open a Cisco TAC case so an ACI engineer can look at your fabric.
Thank you for participating in the Cisco Support Forum for ACI! If you have other questions related to this post, please let us know. If this response answers your questions, please mark this post "answered" and assign a rating to the response(s) provided. This will help notify other viewers that your question(s) is answered and this helps us provide better responses for this and future questions.
Thank you!
T.
06-30-2017 02:26 AM
Thanks Tomas for your response.
Time is in UTC and there is 7 hour difference between controller and leaf. I am able to see APIC in lldp.
(none)# show lldp neighbors
Capability codes:
(R) Router, (B) Bridge, (T) Telephone, (C) DOCSIS Cable Device
(W) WLAN Access Point, (P) Repeater, (S) Station, (O) Other
Device ID Local Intf Hold-time Capability Port ID
APIC1 Eth1/1 120 eth2-2
(none)# cat /mit/sys/summary
state : out-of-service
APIC1# acidiag fnvread
ID Pod ID Name Serial Number IP Address Role State LastUpdMsgId
Total 0 nodes
Is there any other commands in APIC to identify the exact issue?
06-30-2017 05:59 AM
I hope this helps!
T.
07-05-2017 04:50 AM
We adjusted the APIC controller clock same as leaf/spine and it worked. Thanks Tomas!
Kumar
