Best way of fetching summary of contracts to present to Security Folks
julian.bendix
Level 7
Level 7
Hey Team
Maybe strange question .. i am searching if anybody tackled the task to fetch information about all existing contracts of a fabric - suitable for showing it to colleagues from security teams - before.
Just the info which EPGs can communicate with which EPGs over which ports and so an..
I am thinking about writing a script for that, but my scripting knowledge is very limited, that is why my journey begins with searching if there are already solutions out there
Any input would be highly appreciated - thanks a lot in advace!
BR Jules
Marcel Zehnder
Hi @julian.bendix : Your best option is to write a script, see https://github.com/agccie/aci-contract-parser/tree/master as a starting point. If you have troubles writing a script, let me know, I can support you.
Cheers
Marcel
Marcel Zehnder
Cheers
Marcel
Hey @Marcel Zehnder !
Thanks a lot for the hint - i really can pick up from this output and parse it into something that i can show to security colleagues.
Thanks man!!!
